Interesting MEVI oil issue
Last night I was screwing around and decided to remove the MEVI "resonance chamber" cover (where the butterfly valves are located). Low and behold, there was oil that had pooled up around the base of the two far passenger-side butterfly valve ports. I found this interesting because with the USIM, the two far passenger-side runners/ports also typically show oil saturation. The amount of oil I saw was around 1/2 a teaspoon. My PCV valve is in perfect running shape.
Just thought I'd share.
Dave
Dave
Re: Interesting MEVI oil issue
Dave
Dave
Originally posted by 1MAX2NV
EGR??
EGR??
Where does this oil come from? It probably comes from a combo of the EGR, PCV, or valve cover breathers. Why does it accumulate on the far side of the engine? Probably because air velocity is lower on that side, especially during start-up and low rpm cruising.
Dave
pktaske
May 6, 2016 07:49 AM
kjlouis
Oct 3, 2015 05:29 AM
pktaske
Sep 4, 2015 08:40 AM
