Do any of you have the Pace setter short shifter?
Old Jan 16, 2003 | 12:16 PM
hacim105's Avatar
I'm thinking about getting one from custommaxima but I want to make sure it is worthwhile. What are your opinions on the best short shifter?
Old Jan 16, 2003 | 01:43 PM
Lordrandall's Avatar
I will on the 21st. I'll let you know.
Old Jan 16, 2003 | 03:39 PM
2KxSEx's Avatar
Hey,
I have the pacesetter sts. I currently have it set at about 50% of max, and the throw is a lot shorter than stock. No longer do you have to row through the gears. The shifter just sort of snaps into gears. However, in the winter the shifter is a lot harder to shift. It gets stuck inbetween shifts. For example, most of the time I have to rev match going into second gear when the trans is cold. That could be due to the fact that my trans lube is due for a replacement though. Also, my downshifts are a bit rough especially going from 4th into 3rd. Keep in mind that all these little glitches only happen when it's cold outside. Other than that, I love the sts. Wouldn't have it anyother way. Just make sure not to set it more than 50% of max as everybody recommends on the org due to extra wear on the syncros.
Peace.
Old Jan 16, 2003 | 04:43 PM
99Maxima5sp's Avatar
Does it make extra wear AT ALL on the synchros??
About how much shorter would you say it is now, between shifts?
1/4inch, 1/2, 1 inch etc...
Do you have any pics of it installed?
Old Jan 16, 2003 | 05:21 PM
96BLUMAX's Avatar
I have the B&M and i like the feel of that one too. Any sts will be better than stock. Just a personal preference.
Old Jan 16, 2003 | 11:43 PM
VQdriver's Avatar
i've had my pacesetter shifter since the early summer. it works really nice. it's on the shortest possible setting. super short clickety click shifts. no problems during the cold winter months. the only thing i notice is my clutch fluid is so cold the clutch pedal feels mushy until it warms up. you shouldn't have problems shifting it. it will take a little time getting used to the extra effort it takes to shift and the extra short throws. after that, it's second nature again. i would recommend learning how to properly match rev the engine when downshifting. i personally like to double clutch/matchrev every downshift, but that's just me.
Old Jan 17, 2003 | 04:28 AM
T-bone's Avatar
I have the pacesetter STS and I love it. Mine is set at 3/4 max.
Old Jan 17, 2003 | 02:57 PM
2KxSEx's Avatar
The shifts are about 1.5x shorter than stock. I do rev match ever since I got the STS. Sometimes it just doesn't want to go in unless you position the shifter perfectly between the gate.
Peace.
Old Jan 17, 2003 | 03:02 PM
hacim105's Avatar
Peace.
Cool I think I'm going to get it.
How do you rev match?
Old Jan 17, 2003 | 08:09 PM
96BLUMAX's Avatar
Yeah sometimes i have trouble getting it in gear. Most of the time its fine after the car warms up.
Old Jan 17, 2003 | 08:58 PM
Yeah, hows this rev match thing work??
Old Jan 18, 2003 | 12:05 AM
VQdriver's Avatar
www.turnfast.com is a resource you can turn to for roadracing techniques. the rest is practice.
Old Feb 27, 2006 | 12:28 PM
jkmay01's Avatar
Lil 8
i have a pacesetter STS also, only question i had is when driving the car cold the shifts are smooth as butter, but once the car warms up the shifts become sticky as tar!!! seems like the bearing is expanding due to the heat from the cat?? anybody have this same problem? any solutions? let me know? thanks
Old Feb 27, 2006 | 07:12 PM
ColdSHO's Avatar
ive had mine for almsot 3 years now, ive had it at all diff settings, i have it about as low as it can go now, had it there for well over a year. it can take a decent amount of force to move it soemtiems, but it matches the clutch so i like it. i added a heavy knoba nd that made a huge difference, much nicer.
jmlee44
Oct 2, 2022 02:13 PM
Fbana41
Aug 29, 2016 12:18 PM
sliptap
Sep 30, 2015 05:57 AM
atriuum
Sep 28, 2015 01:19 PM
