Brake Caliper$
Old Feb 10, 2003 | 01:16 PM
KsuMax's Avatar
Cheesing away...
Brake Caliper$
Does anyone know why brake calipers are so expensive?
Old Feb 10, 2003 | 04:42 PM
njmaxseltd's Avatar
I didn't think they were very expensive. OEM maybe, but not aftermarket. You can rebuild you old ones with a simple seal kit too. Don't waste your $$$ on new ones when a rebuild usually does the trick.
Old Feb 10, 2003 | 05:05 PM
sidewinder740's Avatar
Would a rebuild get rid of that rubbing noise you get when you just barely have your foot on the brakes? That drives me nuts.
Old Feb 10, 2003 | 07:49 PM
bsetiawan's Avatar
If you are referring to the squealing noise like a pig, that may be your pads or rotors are glazed or they may be dirty.
Old Feb 10, 2003 | 08:44 PM
No it's not squealing---I have no brake squeal. It's just when you barely lift your foot off the brake pedal and it makes a groaning noise. My dad's Acura RL doesn't do it.
Old Feb 10, 2003 | 11:58 PM
SG01MaxSE's Avatar
What you're explaining is normal. Anytime you have two materials (in this case, brake rotors and brake pads) rubbing against each other, there is going to be noise. It means your brakes are working. What's the problem? Is it outrageously loud or something?
Old Feb 11, 2003 | 05:59 AM
No, not outrageously loud, it's just annoying. I was just wondering if a caliper rebuild/lube would fix it, that's all.
Old Feb 11, 2003 | 06:48 AM
Stephen Max's Avatar
You mean the groaning you get when you're stopped and you just barely ease up on the brake pedal so that the car creeps forward but with the pads still touching the rotor? I could do that with every car I've ever owned that had an automatic. It is a phenomenon of sliding contact called stick-slip, where alternating sticking and slipping of the rotor against the pads excites natural frequencies in the rotors, calipers and probably other parts as well. It's perfectly harmless. I love doing it - annoys the hell outa the wife.
Old Feb 11, 2003 | 10:16 AM
2kSeattleMax's Avatar
Why not change your pad compound?
Old Feb 11, 2003 | 11:10 AM
slavik'sMAX's Avatar
i also think trying new pads (like QuiteStops) would help
Old Feb 11, 2003 | 12:03 PM
Yeah...that's what I'm talking about. It's weird because my dad's 2002 Acura RL (auto) doesn't do it no matter how hard I try. I was just wondering if you could get rid of it on the Max. But if it is normal and everybody has it I guess it's cool haha.
Old Feb 11, 2003 | 12:51 PM
hakk97se's Avatar
Mine doesn't do it unless it's *really* cold out. I have sumitomo pads on oem calipers/rotors. Im about to go Brembo/Porterfield tho.. I hope I dont get that sound all the time, that would drive me nuts.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
