Going over speed bumps
Old Feb 11, 2003 | 07:38 PM
95maxima's Avatar
I dont know too much about suspension on cars but lately when i go over high speed bumps, the front shocks make a relatively noticeable compressing sound. What do i need to change?? my brother says i need to change the struts, someone else said i needed to change the shocks. What do i need to change???
Old Feb 11, 2003 | 08:00 PM
CBass69187's Avatar
Re: Going over speed bumps
Shocks and struts are both a form of damper. How many miles do you have on your struts and what kind? Sounds like they may need replacing.
Old Feb 11, 2003 | 08:40 PM
Wisky97SE's Avatar
I think they were both referring to the struts of the Maxima - the maxima has struts all around. It used to be in my altima that in the cold it would make a compressing sound when going over bumps - im pretty sure it was the struts, use it as an excuse to get some KYB AGX's, or Tokicos . Unless they're the bushings? But I doubt it.
Old Feb 12, 2003 | 05:52 AM
njmaxseltd's Avatar
What your hearing is the hydraulic fluid being ported through the valves within the strut as the piston shaft moves in and out.
It's normal, actually thats a good noise. If and when that stops happening, your struts aren't dampening anymore.
Old Feb 12, 2003 | 07:05 AM
Str8ridin's Avatar
and that noise usually occurs when you go really fast over the speed bumps. is that the case?
Old Feb 12, 2003 | 07:09 AM
njmaxseltd's Avatar
Re: Re: Going over speed bumps
You don't have to go fast, just get the piston to stroke nicely and you'll hear it.
Sounds like "hissss - hissss", piston in, piston out.
knight_yyz
Nov 1, 2015 01:34 PM
Need help
23
Oct 2, 2015 08:56 AM
uttadms31
Sep 30, 2015 05:24 AM
Marc2theMax
Sep 28, 2015 08:13 AM
