Piece of air filter destroys turbo.....
Turtle turtle... Moderator
so i got my new MAF today, took off the old one and i noticed the screen was torn. so i look in the tubing and there is a small round metal piece. im like WTF is that? turns out its part of the air filter that came apart, so i take a peep at my turbine...juss as i thought, the metal piece hit the turbine and destroyed the blades and ruined the seal....GREAT.
Re: Piece of air filter destroys turbo.....
awww man. that sucks dude.
Yea I would like to know which kind of filter that was as well?
Right now im using an aFe filter. Is it known to be as good or better than the Apexi. Main reason because the aFe is still a wet filter and not a dry one.
Dixit
Dixit
Originally posted by d_warner
My question is: How much debris got through the turbo and into the motor? Replacing the turbo is quite a bit cheaper than replacing the motor. Less time consuming too.
David
David
sheeesh i kept telling him to replace that bunk air filter..the top corner is all ground up from rubbing a hole though the fender liner..tsk tsk..
David
David
Can you imagine what that would sound like if it got all the way to the engine?
Just FYI while we're on the topic...never use a foam filter with a turbo. Alot of people do it, but its an extra risk you don't have to take. Those compressor blades are spinning at over 100,000 rpm and one small peice can wreak havoc.
Jesse
Jesse
jmlee44
10-02-2022 02:13 PM
06-06-2017 02:01 PM
Maximeltman
09-28-2015 07:19 PM
