Will 2k muffler flow as good as stillen>>
Old Jan 11, 2001 | 02:31 PM
98MAX's Avatar
I think not really, but is the power diff worth losing the noise from the stillen muffler? I have been running my stock muffler couse it is so loud, would a 2k muffler give me at least a couple of ponies over stock and still be quieter than the stillen?
Old Jan 11, 2001 | 02:59 PM
Jeff92se's Avatar
I'm needing a caw
I run a Cattman Y, RT cat custom cat back and a Y2K muffler on my 3-gen. Now it has taken me alot of time and $$ to get this system correct. Here's what I did.
1) I had a shop re-do the flat flanges on the rt cat to ball-joint type. Fixed the crappy exhaust leaks and helped the noise slightly.
2) My flex-joint was leaking but I couldn't track it down until I got the rest of the styem fixed first. It turns out the flex was responsible for 90% of the crappy bees in the can noise. Now cattman's y is not Stillen's Y but I suspect that they BOTH used UNLINED flex sections in their designs. Which sucks big time. I had the shop use a LINED flex section and BLAMO! Dead quiet exhaust. A slight hiss but it could be another slight crush ring leak I think. I mean it's STOCK quiet and my system is far from stock now.
Old Jan 11, 2001 | 03:07 PM
TAGURIT's Avatar
there should be a big difference because the stillen is a straight thru muffeler and if you look at it you can see right thru it as for the 2k mfflker it is still more restrictive no matter what people tell you the stillen one adds more hp but the 2k muffler is much more quiet and better off that wayand probably gives u more low end power.
98MAX's Avatar
Damn, thats nice. That might be my next move, I just cant handle the noise anymore.You you a 3 inch high flow cat?
Old Jan 11, 2001 | 03:14 PM
Jeff92se's Avatar
I'm needing a caw
98 Max. No that's probably too big and it's alot bigger than the outlet of the Stillen Y anyway. I have the RT cat that's 2.5"
Old Jan 11, 2001 | 05:32 PM
ericdwong's Avatar
Jeff, was it worth it for all this effort? I just dropped in a Y pipe, but the 2K muffler is very expensive, as is the Courtesy B pipe.
Old Jan 11, 2001 | 06:51 PM
Kevin Wong's Avatar
2000 muffler
Check the salvaged yards, my friend bought one for $60
AcuraLegend
Oct 17, 2016 08:47 PM
cruce91
Sep 20, 2015 10:23 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
Justin Kroll
Sep 2, 2015 11:06 AM
