Tranny Cooler
Old Mar 4, 2003 | 06:49 AM
foodmanry's Avatar
Da Roller Coaster!
Tranny Cooler
This is for those of you who have experience with an AT tranny cooler. I am looking to do a VB mod sometime, but not anytime soon. If I was to install a tranny cooler prior to the VB mod how would that affect my tranny performance?
Right now I am not particularly hard on the tranny and it has been fixed for the slippage in the past. I live in a temperatre climate in Southern California so it does not get exceptionally cold or hot.
Would I start to experience some rougher shifting because of the cooling effect? Would the tranny still be within operating temperature?
Any help would be appreciated.
Thanks.
Ryan
Old Mar 4, 2003 | 07:33 AM
ZuMBLe's Avatar
Re: Tranny Cooler
You won't see any drawbacks. It may shift rough in the mornings because the fluid won't warm as quick. But it will keep your fluid nice and cool once the car is at operating temp. I had my tranny cooler before my vb mod.
Thanks.
Ryan
Old Mar 4, 2003 | 07:38 AM
foodmanry's Avatar
Da Roller Coaster!
Re: Re: Tranny Cooler
Sweet. Thanks for the reply. That's all I needed to know.
Old Mar 4, 2003 | 08:00 AM
ZuMBLe's Avatar
Re: Re: Re: Tranny Cooler
Remember to add fluid after adding the cooler! You're adding more volume to the tranny system so you have to add more fluid. Check your manual for instructions on how to check the fluid levels.
ZuM
Old Mar 4, 2003 | 08:21 AM
jdm_mboy's Avatar
Re: Re: Re: Re: Tranny Cooler
ZuM
Are these things hard to install?
Old Mar 4, 2003 | 09:38 AM
redmaxpa007's Avatar
i SeE what you did therE
Re: Re: Re: Re: Re: Tranny Cooler
no
Old Mar 4, 2003 | 10:03 AM
Jime's Avatar
If you buy a B&M it will not run any cooler in the winter because it bypasses when the fluid is cool. Until it warms up that is.
Old Mar 4, 2003 | 10:24 AM
ZuMBLe's Avatar
You just need a few basic hand tools. The instructions that come with the cooler should be more than enough. Do a search for "transmission cooler install". You may find pictorial instructions on the install for the maxima.
Old Mar 4, 2003 | 10:27 AM
XXXL Cracker's Avatar
Re: Re: Re: Re: Re: Re: Tranny Cooler
Originally posted by redmaxpa007
no
At least not if you have the right fittings, right Jeff?
I also installed mine pre - VB mod and noticed nothing different.
D
Old Mar 4, 2003 | 10:35 AM
BlackCat's Avatar
RIP '98 Maxima SE
Ahhh...no wonder my tranny shifts a bit rough on these cold mornings!
Old Mar 4, 2003 | 10:51 AM
Shaydz's Avatar
I know that's the way is supposed to work, but I have the B&M Supercooler and it takes a long time for warmup of the tranny (lack of smooth shifting at throttle - Auto) on very cold days (freezing temps - 20 mins of driving at least). I've actually considered unhooking it except for racing or until the spring gets going. Looking forward to the summer though.
When you install it be gentle against your radiator when you mount it - the radiator fins are VERY fragile and bend easily.
Otherwise, it's just a tight fit to mount the cooler itself with the retaining ties - everything else is a breeze.
Old Mar 4, 2003 | 11:03 AM
Jime's Avatar
I have the largest one they make and even at -25 yesterday it was fine so maybe your by-pass is not working properly.
Old Mar 4, 2003 | 11:52 AM
foodmanry's Avatar
Da Roller Coaster!
Which one did you get and where did you get it?
Old Mar 4, 2003 | 11:59 AM
Shaydz's Avatar
How long does it take you to warm up where the tranny (at WOT) shifts smoothly? Surely it's not immediate.
It may be my bypass because it does take some time for me. However, to be honest, it took a little while before the cooler was installed. I just wasn't noticing the amount of time then. Plus, I changed to Amsoil Sythetic at the same time and that's supposed to be much lower in temp.
Might be a combination of things.
Old Mar 4, 2003 | 12:26 PM
Jime's Avatar
I bought mine at Canadian Tire in Canada, its 11x11x3/4 and rated at 24,000 GVW. I figured since it had the bypass I would buy the largest one they had.
Shaydz
I don't go WOT when the car is cold but it shifts very quickly right away at part throttle and I don't let my car warm up any longer than 30 secs or so.
Old Mar 4, 2003 | 12:43 PM
Shaydz's Avatar
Shaydz
I do the same (around 30 secs - 1 min). And I never WOT right away either. But I do test it around 5 min intervals to see if it's warmed up for full throttle. Seems in cold weather (<32deg) 20 mins is the magic number. I have the same cooler. I got it from jegs.com for $49.
Today it's high 50's in NC. Should be much better.
tarun900
19
Dec 20, 2021 06:57 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
catalinvint
Sep 16, 2015 07:48 PM
pktaske
Sep 4, 2015 08:40 AM
