Instead of Maxima CF Hoods, This is What Came in ..
It looks like to me that it will fit with minimal custom work. But, it is apparent that the only thing that is holding us back is the steep angle on the outside of the headlight where the corner light would match up with the headlight. I am sure that this could be worked on with time, but the last thing we need is a gap in between the headlight and the corner light. Since we all love the one-piece headlight concept, it would be hard to deal with a DEFINITE corner light and DEFINITE headlight combo.....But would still be a better alternative to what we have now......which is nothing lol....
Hey Ange, can you do me a favor? Can you give me the dimensions of the headlight itself? Like, I need the bottom (corner to corner) measurement, the top (corner to corner) measurement, the grille side measurement, top to bottom, and the corner light side measurement (top to bottom). Thanks Ange, if I get what I can, I may be able to fit these onto our Maxipads.......
Re: ...and guess what?
Originally posted by 97MaxGurl
Here are my groupdeal prices for the Sentra Angel eye headlamps..
5+ Order Groupdeal: $240.99/pair
10+ Order Groupdeal: $229.99/pair
20+ Order Groupdeal: $199.99/pair
30+ Order Groupdeal: $184.99/pair
The Sentra boards are b!tching about my prices.
I am not an expert on headlights but isn't the main reason our headlights suck the crappy 9004 bulb? (plus the poor reflctor design) If you are making new headlights why would you use this same bulb? The 9004 is a dual filiment anyway, and these have separate high and low beams, so it could not be 9004s, Right?
Is the angel eye ring hooked up seprately? Do you have the option of turning it on how you want to or leaving it disconnected? Or is it wired into the low beam somehow?
Chick specializing in rounding up 100+ Maximas
Anachronism: OE Sentra headlamps uses 9004, just like us 4th gens. *edit* Not sure about these. I'll have to find out. I'll find time to test fit them (when it's above freezing here). I may need some help though (since I don't have dremel
).Cumalittle: Just started my business, can't really afford to send things back and forth. But thanks for your offer though.
AnGe
Re: Re: ...and guess what?
Originally posted by Canuck
If they use 9004 bulbs why are there two lamps?
.. I'll find out before end of today. Unless there's someone more knowledgable in Sentras that care to shed light on this subject.
I think stock sentra lights are 9004 but the angel eyes have 2 lamps which sugests that they use two single filament bulbs instead of one dual fillament.
Anyway, I'm not going back to the Sentra boards to ask them, they practically booted me out b/c of my pricing.
Originally posted by Supa Lao
it's just a 9004 harness on the back of the headlight, so you can just plug in the factory harness in there. They are not 9004 bulbs in the housing, definitly some other size.
If they are fit 4th gens I think I'll have to get a set
and hope this BS Northeast weather changes (and i don't mean snow change into ice like today) for the better this Sunday so I can test fit those puppies.
AnGe
YourLocalAsian
Aug 17, 2015 02:33 PM
wingsfan24
Aug 15, 2015 07:35 PM
doobadoo
Aug 15, 2015 06:43 PM
ramtin325i
Aug 8, 2015 05:13 PM
