eibach or sprints
Old Mar 7, 2003 | 11:44 AM
mayhemI30's Avatar
"I'm running with scissors!"
eibach or sprints
right now i have eibachs, i like the ride but it isn't low enough. should i sell my eibachs and get some sprints?.
Old Mar 7, 2003 | 12:19 PM
190hpKiLLA's Avatar
Granny Driven
Re: eibach or sprints
You can try but eibachs are known to sit very low, lower then they specify. With sprints you supposedly will go lover but will loose the great handeling but will gain more comfortable ride.
Just cut the freaking eibacks. In worst case scenerio you will get new springs if you dont like the ride with the cut coils. Many people have done it and they dont seem to have any problems. One coil cut of each spring wont do u any harm.
Old Mar 7, 2003 | 12:22 PM
mayhemI30's Avatar
should i cut the ciol at the top or bottom?
Old Mar 7, 2003 | 12:24 PM
190hpKiLLA's Avatar
Granny Driven
Damn that i forgot, why dont you go to a respectable shop and let them do it.
Old Mar 7, 2003 | 12:32 PM
mayhemI30's Avatar
if i put some kyb agx do you think eveything would still be fine
Old Mar 7, 2003 | 07:40 PM
BBaker025's Avatar
get progress
Old Mar 7, 2003 | 10:25 PM
ch13f's Avatar
If you are running on the stock struts now its just a matter of time before they blow, Eibach, while not too low are quite stiff. You actually may want to consider Intrax springs with one coil cut in the front. They are progressive springs just like eibach and are quite a bit lower, so handling may even improve. Definatly upgrade your struts, and put them in at the same time as the new springs, save some money on labor, or time if you do it yourself.
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
morteljc
Oct 19, 2015 10:47 AM
95Maxi
35
Sep 2, 2015 10:37 AM
official_style
Aug 29, 2015 10:10 AM
