CARCHIP Performance Monitor - is this thing for real?...
Choose one of the CARCHIP links & look at the "DETAILS" link at the bottom:
http://www.provantage.com/FC_DAVC.HTM
Says it uses the ODB-II interface...
G
Haha... I'd love to search, but it's disabled tonight...
G
Re: CARCHIP Performance Monitor - is this thing for real?...
G
G
Originally posted by 95emeraldgxe
125 bucks, think its worth it?
G
G
Re: Re: CARCHIP Performance Monitor - is this thing for real?...
Originally posted by ivelweyz
You do know that this thing does absolutely nothing for performance of any kind, right? You plug this in drive with it and hook it up to your PC. It tells you your max speed(max speed you drove at) hard braking, trip length and all that crap. They had this on so many car shows on TV it's not even funny...
More cool features of the E/X chip:
RPM
Throttle position
Engine load
Coolant temperature
Intake manifold pressure
Air flow rate
Intake air temperature
Timing advance
Fuel pressure
Fuel system status
Short and longterm fuel trim
Oxygen sensor output voltage
Battery voltage
G
Re: Re: Re: CARCHIP Performance Monitor - is this thing for real?...
you did see the part about "measures up to four engine parameters" so you can choose 4 of the ones on that list to record.
if all you want to do is use this to record/check stuff, there are better options. If you want to use it to keep track of another driver this might be the best thing because it can easily be hidden.
search around for "car software odbii palm" in google and read a little about other stuff available.
I am aware. But you can read error codes with it according to the details. That's what I'd like to use it for.
RPM
Throttle position
Engine load
Coolant temperature
Air flow rate
Timing advance
Fuel pressure
Fuel system status
Battery voltage
G
RPM
Throttle position
Engine load
Coolant temperature
Air flow rate
Timing advance
Fuel pressure
Fuel system status
Battery voltage
G
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
RWCreative
Sep 21, 2015 11:01 AM
