tire tread direction question
Old Mar 13, 2003 | 03:13 PM
sil SE's Avatar
i have 4 continental contisportcontacts on. i dont know of any opinions on these so if you know that they are good or bad let me know.
but anyway, my question has to do with direction.
on all 4 wheels the direction is facing the same way.
which means, on one side of the car theyre facing forward while on the other side of the car theyre pointing backwards.
is something wrong? i bought these second hand.
Old Mar 13, 2003 | 03:20 PM
Nick97SE's Avatar
I believe that the direction arrows are always supposed to face forward.
And they are good tires. I had them on my OEM 16s.
-Nick
Old Mar 13, 2003 | 03:35 PM
sil SE's Avatar
thanks nick
btw, theres no directional arrow or rotational stuff..
it just says OUTSIDE
http://www.tirerack.com/tires/tires....omCompare1=yes
Old Mar 13, 2003 | 03:42 PM
REVHIGH's Avatar
I think you're OK
If there's no arrow saying "Direction of Rotation" stamped on the sidewall, then they're not unidirectional. If there's an "outside" stamped on the tire and they're all the same ("outside" out) you're fine.
Old Mar 13, 2003 | 06:13 PM
foodmanry's Avatar
Da Roller Coaster!
No arrow mean bi-directional as stated before. Meaning you can run the tires forward or backward. Know what I'm saying?
Now the outside/inside means assymetrical. This basically means that the outside must run on the outside of the car and the inside must run on the inside. So if they all say outside, then you are ok.
Good thing about those tires is you can rotate them the 4-way so they all get even wear.
Old Mar 13, 2003 | 09:17 PM
sil SE's Avatar
ok so even though its facing a differnt way, iits alright as long as the tire outside is mounted right.
thanks!
so i can rotate these like normal radials?
is that what you mean?
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
dutch078
Wheels/Tires
Aug 3, 2015 06:58 PM
