!!!Technical Help Needed ASAP: Kev, Others....
Old Mar 14, 2003 | 05:09 AM
rp95se's Avatar
Max finally needs help.
Changed sparks, belts, radiator fluid recently.
Also Y Pipe had cracked after 3 years or so of use, so swapped old manifold back in.
Now car wont idle properly. Its at Buckeye Nissan and they are claiming it may require an Idle Air CV for $250. Anybody ever heard of this problem?? They are first replacing the Coolant Temp Sensor.
Please Respond ASAP
Old Mar 14, 2003 | 07:38 AM
njmaxseltd's Avatar
You can test the coolant temp sensor with an ohm meter to see if it's within specs.
You can clean the IACV relatively easily.
You should clean your Throttle body
GET YOUR CAR BACK FROM THE DEALER. With the help of the org, we can save you $$$ and get your car gack in tip top condition.
Old Mar 14, 2003 | 08:24 AM
chinaonnitrous1's Avatar
yeah serious, dealer= !!
smplyamzng
Dec 13, 2015 01:19 PM
SmokinMax02
18
Sep 11, 2015 12:25 AM
drworsley
Aug 20, 2015 05:07 AM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
