What are the benefits of changing a PCV valve?
Old Mar 16, 2003 | 01:32 PM
MaxPerformanceSE's Avatar
About two weeks ago a Nissan mechanic suggested I change the PCV valve. I finally got it done today. What can I expect from a new PCV valve?
Old Mar 17, 2003 | 07:18 PM
pjalst
Re: What are the benefits of changing a PCV valve?
was it hard to change?
Old Mar 17, 2003 | 08:13 PM
karguy's Avatar
It depends on condition of old PC Valve. It could smooth out idle or reduce crankcase pressure to eliminate or prevent oil leaks.
Old Mar 17, 2003 | 08:30 PM
][ 35's Avatar
is changing out pcv something that is easy to change out or something that is need to be done by mechanic? if so what is the cost around?
Old Mar 17, 2003 | 09:34 PM
kushane's Avatar
On my 4th gen - took a grand total of around 5 minutes to change it. If you can use a pair of pliers and a 10mm wrench , oh and find where it's located at , should be no problem at all. Oh - and I don't know how much it helps - but the old pcv valve sure looked ugly and burnt after 70k miles.
Old Mar 17, 2003 | 09:35 PM
iansw's Avatar
A set of door panel poppers works great for getting it out.....
Old Mar 17, 2003 | 10:02 PM
][ 35's Avatar
any pic of where they are located at? or link that shows how to change it?
Old Mar 18, 2003 | 01:42 AM
Bgohan's Avatar
Originally posted by 98coupev6
nothing really...i think...it's more of maintenance issue.......
WHAT???
A malfuntioning PCV valve can cause a host of problems, from vaccuum problems to mileage drop to rough idling, to name a few, of many.
The valve is a relatively cheap part, and usually does not fail on newer cleaner running cars. But it's a good idea to change it out when you change your plugs at 60K intervals. Always change out plugs first, drive car, then change valve. If car does not run properly after replacements, you can pinpoint a problem easier.
This is a good practice to follow for many types of multiple part replacement/repairs.
Old Mar 18, 2003 | 06:09 AM
virus99's Avatar
Originally posted by Bgohan
WHAT???
humm..... i been getting pretty bad gas mileage around 20 MPG on normal driving w/o any WOT.... i was blaming on the new y pipe...... i do have around 45k miles on the car....... need to check on it....
so any link to show pic of the part and where? or even better if there is link that shows how to replace it..
Old Mar 18, 2003 | 11:06 AM
pjalst
Pics, pics we need pics!!!
Old Mar 18, 2003 | 11:12 AM
][ 35's Avatar
yes pic would be nice.... my car part of the brain isn't developed well so the pic speaks a 100000000000000000000000000000 words...
Old Mar 18, 2003 | 11:42 AM
I30tMikeD's Avatar
Pics = Haynes Manual
Write up = Haynes Manual
Old Mar 18, 2003 | 03:14 PM
][ 35's Avatar
went to haynes site looked up for maxima but it only has it till 01... don't want to order it and find out it won't help with I35 much... so will that book till 01 be useful for my car 2002 I35?
Old Mar 18, 2003 | 09:18 PM
I30tMikeD's Avatar
Good question. I'd ask the guys in the 5th gen forum.
Old Mar 18, 2003 | 09:37 PM
1MAX2NV's Avatar
On the 4th gen, it's on the rear valve cover. If you peek down under the upper intake manifold, you will see a hose/PCV valve. You can just clean up the valve with some carb cleaner. I wouldn't buy a new one unless the old one is cracked or totally gunked up.
Old Mar 19, 2003 | 01:20 AM
Bgohan's Avatar
Replacing PCV valve is part of 60k tune up on Max. Other cars usually suggest to change it every time you change park plugs. It is probably just fine 95% of the time, but is a cheap part (usually less than $5.00). You can even clean it by soaking in carb cleaner to get by if you are broke or cheap, like me. Newer cars don't gunk them up fast because the engines run cleaner. If you have high mileage, it might gunk up faster. Also, if certain other parts fail, the valve will gunk up faster. It may not fail at 60k, but may fail at 114,198.6 miles, before you get around to changing plugs again, and give you fits and nightmnares and give a dealer an excuse to charge you $500 to "fix" your car after you cant figure out why it runs like crap.
Also, on the 4th gen, it is a bee-otch to change. It's in a tight spot and hoses are perma-stuck on the valve. *Yanking It can bust your knuckles bad, not to mention bending and damaging other parts. So, buy some 3/8 PCV/fuel line hose (10" is more than enough**) when you buy a new valve, and cut the old hoses to get old valve off. Slice it up the sides so you can still use it to measure length for new hose.
*Hose on car.
** Thats what she said, anyway.
Old Mar 19, 2003 | 05:45 AM
pjalst
*Hose on car.
Good advice, now if I can only find it.
Old Mar 19, 2003 | 06:40 AM
I30tMikeD's Avatar
*Hose on car.
I agree, some people have said it's real eazy to replace. It sure wasn't for me. I had to ende up cutting it off and replacing the hose as well.
Old Mar 19, 2003 | 07:02 AM
DaBoxSE's Avatar
I can't find the damn thing on my VE. I was told it was somewhere behind the intake manifold. Its a tight spot back there!*
Old Mar 19, 2003 | 09:33 AM
kushane's Avatar
http://web.archive.org/web/200111091...k_service.html - see #6
Credit: Jeff Ketch
Guys this was from the great article on how to perform the 60k service on the max which is no longer hosted at integra.vtec.net. I am awaiting on permission from the author to host this on my website so us 4th genners can access it freely.
Old Aug 28, 2025 | 05:49 PM
123GO's Avatar
PCV Problems you say?
Two issues I had started when the PCV started sticking closed. When one sticks shut the internal pressure builds up inside your engine & blows out gaskets & seals creating oil leaks. Trust me, that pressure finds its way out.
Much easier/ cheaper changing a PCV valve than pulling the trans or engine to replace your rear main seal. Im lucky so far?
Ive seen it so many times and even watched people replace gaskets/seals only for it to happen again, oh and again...yup! Just wouldn't believe a crazy old man I guess? Ive only owned 200+ vehicles so I don't know much yet?..lol
PCV is one of the most overlooked parts under our hoods yet cost us thousands by ignoring it repeatedly. Old car owners manuals had maintenence schedules inside that listed PCV inspect/replace. When car makers still cared, in a galaxy far far away.(not a Ford Galaxy, I may want to return)
Also a sticky PCV can turn everything inside an engine bronze or copper toned when it fails. Heat builds up & breaks oil down similar to sludge but this heat isn't as high from PCV failures most times so its a very thin coating that usually wipes out of valve covers, pans etc much easier than actual sludge.
I can tell you from experience its not from too long of OC intervals. Mechs are too quick to sludge judge on the copper tone engines they see.
My wifes I30 has had Mobil 1 full syn 10k now 15k I think, all we used since new with 6k mile intervals. Its stick was was never stained till its PCV stuck. I changed its PCV around 80k, its at 155k now give or take? I saw how bad it was stained inside after pulling off my leaky valve cover. The oil pans leaking also, this car never leaked. PCV failed the shake test, Its the blue/white plastic USA made version, mines Beck branded but its found under most brand names.
The one I bought to replace mine broke in half right in my hand just pushing/turning it in the grommet. Im a disabled 63 yr old, Im no Arnold here guys/gals, these are absolute trash!
I bought a metal body design, very easy upgrade. My 2000 I30 3.0 V6 PCV is in the intake just under the throttle body fwiw.
Hard to see it but its in there. Stand by drivers front wheel with a flashlight at night you'll see it best. Look for the small/medium size hoses clamped together & follow them to their end, its on the bigger one looking straight in.
Peace
Old Aug 29, 2025 | 11:13 AM
slvr2KSE5's Avatar
the pressure will find its way right out.....into the breather hose that is free flowing and plumbed into the intake tube.
JoshG
51
Sep 21, 2015 10:41 PM
bumpypickle
Sep 20, 2015 08:22 AM
Steven Orozco
Sep 12, 2015 10:41 PM
