I need help with my AUTOMAGIC!
Old Mar 16, 2003 | 06:16 PM
tampamax's Avatar
How can I get the tranny to let me do the 1-2 and 2-3 shifts when I want? Someone has to know of a way to maually shift the auto before it starts to rev outside its power band.
Thanks in advance.
Old Mar 16, 2003 | 06:28 PM
gtr_rider's Avatar
192.168.1.1
Re: I need help with my AUTOMAGIC!
Thanks in advance.
umm
Old Mar 16, 2003 | 06:32 PM
Bags's Avatar
VG Ridah's Biatch Hoe
what power band is THAT???
What rpm do you want to shift at??
There are many ways to shift your auto.. takes time and practice
Old Mar 16, 2003 | 07:45 PM
tampamax's Avatar
I'm looking to get the car to shift at 5200-5500.
Please explain to me how to get the car to shift before 6,000. It doesn't matter if I start with the gear selector in 1st and try to bump the selector to 2nd the car will not shift until 6,000 rpms. Can I do something to get around that. The reason I ask this is because the car doesn't feel to be pulling at all after 5200rpm. I want to stay in as much of the torque curve 'before' it starts to fall off.
Old Mar 16, 2003 | 07:46 PM
Sprint's Avatar
Old Mar 16, 2003 | 07:51 PM
tampamax's Avatar
Re: Re: I need help with my AUTOMAGIC!
Originally posted by SprintMax
I know, I know....I just feel the car runs out of breath and I feel it is keeping at least a half second off my 1/4 mile. Some informative feedback would be helpful though. Flame me I don't care. I just want to find a way to get the car to shift earlier.
Old Mar 17, 2003 | 01:50 AM
Bags's Avatar
It will take practice, but lift of the throttle just before you want the shift. Not all the way, just 1/2. And the tranny will shift.
Again it takes practice to get it right. And this can be done in "D"
Old Mar 17, 2003 | 02:19 AM
Dev's Avatar
Dev
just so you know...you won't achieve faster times by doing this, because as you are getting out of your power band at 6000rpm or whatever, when it shifts your rpms are going to be dropped below your power band...
anyhow, for your question, get off the throttle when you want it to shift, then get back on it.
again if you want to go faster, just floor it and let it shift, or even manually shift so it goes past the limiter.
Old Mar 17, 2003 | 04:31 AM
Nismo87SE's Avatar
That is easy. Design a circuit with external over ride controls to the shift soleniods. DBM posted all the info you need, but good luck finding it .
Thanks in advance.
Old Mar 17, 2003 | 05:01 AM
Lime's Avatar
you mean this? (thread id=29949)
I imagine a person with good electronics "savvy" could do this for less than $25. My Maxima is a 5-speed so I can't do it.
This is "top of the head" (i.e. untested) engineering. My idea is to disconnect harness connector F42 and fashion a substitute electrical connector. Run the new harness into the passenger compartment. Mount a 5-position radio pushbutton switch to your homemade harness. The five buttons would control automatic gears 1, 2, 3, 4, and R.
Viewing the open end of connector F42 with the latch at the "12 o'clock" position you see two rows of four terminals. They are numbered 1-4 (left-to-right, top row) and 5-8 (left-to-right, bottom row). Terminal assignments are:
1 = Shift solenoid B
2 = Shift solenoid A
3 = Overrun clutch solenoid valve
4 = Line pressure solenoid valve
5 = Torque converter clutch solenoid valve
6 = ?
7 = ?
8 = ?
The question marks may be filled in by inspection of the connector and tests with an ohmmeter. One of them is for Reverse. The remaining one or two may be grounds.
The activation schedule for the solenoids is:
1st gear = A and B
2nd gear = B
3rd gear = (none)
4th gear = A
The Line valve solenoid would be energized if shift solenoid A, B, or both were energized, and de-powered during shifts.
I hope "Don in Texas" or other Maxima.Org members who know automatics will comment on this idea. Maybe it's whacko. Maybe it's do-able. Maybe it's not worth the trouble.
There is a link to i30's thing: http://forums.maxima.org/showthread.php?threadid=20627
Old Mar 17, 2003 | 05:10 AM
deezo's Avatar
Glad to see someone else here knows what I've been telling some of these guys around here.
Old Mar 17, 2003 | 07:51 AM
tampamax's Avatar
I know about this method, but I wanted to fing out if there are any different methods without getting out of the gas.
Old Mar 17, 2003 | 10:20 AM
deezo's Avatar
There aren't.
Old Mar 17, 2003 | 05:43 PM
tampamax's Avatar
Originally posted by deezo
There aren't.
Are you sure? Or is it that nobody has figured this one out. If only I were an engineer.
KniGhtRydeR
Nov 13, 2001 09:21 PM
1Phat Max
Nov 11, 2001 09:42 PM
stevechen
Oct 22, 2001 02:42 PM
Pat DiPersia
37
Oct 18, 2001 06:28 PM
yongjun
39
Oct 9, 2001 10:31 AM
