Need to replace my transmission rotor and pad...
Old Mar 17, 2003 | 09:43 PM
dmontzsta's Avatar
Ford Only.
I knew that would make someone look. I am starting to hear a loud grinding noise from inside my car. It kind of sounds like worn out pads grinding the rotor, but it is the transmission. It is when accelerating and decellerating below 4k rpm, it is a grinding (not good) sound. Anyone had experience with this? I notice it is slightly there at an idle, then I push in the clutch and it goes away within 2 seconds, then I let out of the clutch and it comes back. VERY loud in the cockpit while driving though. If any of you have had this happen, please let me know.
Thanks in advance.
Old Mar 18, 2003 | 12:22 AM
Soon2BMaxed's Avatar
Re: Need to replace my transmission rotor and pad...
Thanks in advance.
maybe the throwout bearing?
Old Mar 18, 2003 | 03:59 AM
iwannabmw's Avatar
That did make me look.
I think soon2bemaxed was right, it sounds like the throwout bearing.
Old Mar 18, 2003 | 07:20 AM
MaximaMoJo's Avatar
It is probably the throwout bearing. My Ford Ranger did the same thing and it was the throwout bearing causing the problem. This happened right after I had the clutch and throwout bearing replaced. Just needed adjustment, still had to drop the tranny though.
Old Mar 18, 2003 | 07:42 AM
dmontzsta's Avatar
Ford Only.
I just replaced the throwout bearing on saturday.
What else could it be?
Old Mar 18, 2003 | 11:10 AM
Matt93SE's Avatar
STFU n00b!
was it making the same noise before and after? if so, then it's bearings in the tranny. just pull it and have it rebuilt. the sooner you stop asking the same question in 25 forums, the sooner you can start the repair, and the sooner you can get the car back on the road.
Old Mar 18, 2003 | 11:42 AM
dmontzsta's Avatar
Ford Only.
Yes, before and after.
And it is only 2 forums.
Matt93SE
May 24, 2019 02:58 PM
homeyclaus
Sep 3, 2015 06:15 PM
Cant_Get_Ryte
Aug 28, 2015 06:41 AM
RealityCheck
Aug 5, 2015 06:18 AM
