Q: What to look for in a door lubrifier
Old Mar 19, 2003 | 04:58 PM
bert's Avatar
Well, most of my doors feel like a 200 pound brick, gotta lube-em!
What should I be looking for. I would look for some graphite stuff, preferably dry. I am just worried about the graphite shorting out stuff.
Comments?
Old Mar 19, 2003 | 05:32 PM
Kashoggio's Avatar
Nissan uses white lithium grease
Old Mar 19, 2003 | 05:56 PM
maxfanfromohio's Avatar
Shiver me timbers.
I use KY. I would also recommend white lithium grease, for your doors.
Old Mar 19, 2003 | 06:43 PM
bert's Avatar
KY... slipperyness....
Lithium... mental stability....
Still undecided! (I need both though!)
Old Mar 19, 2003 | 07:45 PM
mzmtg's Avatar
Minister of Silly Walks
"lubrifier"
Old Mar 19, 2003 | 07:51 PM
Kashoggio's Avatar
Originally posted by mzmtg
"lubrifier"
Old Mar 19, 2003 | 07:52 PM
redmaxpa007's Avatar
i SeE what you did therE
"lubrifier"
Old Mar 20, 2003 | 11:51 AM
XXXL Cracker's Avatar
Originally posted by redmaxpa007
Old Mar 20, 2003 | 11:54 AM
nadir_s's Avatar
vicodin ... gift of life
my doors feel a bit "loose"... at least the driver side does! I want to get that sturdy feeling back. Tighten bolts??
Old Mar 20, 2003 | 09:33 PM
SG01MaxSE's Avatar
Yeah. Just be sure to lubrify them first.
Old Mar 21, 2003 | 08:05 AM
MChapel's Avatar
OK, guys. Let's cut Bert some slack. English is not his native language and he probably doesn't speak it very much day-to-day. In his language you amplificate (not amplify) and you lubrificate (as opposed to lubricate)....
Old Mar 21, 2003 | 10:06 AM
MaximaMoJo's Avatar
OK, Well my drivers door was sticking so I used white lithium and it made it worse. The grease is thick and wouldn't allow the door to open smoothly. I like for my doors to shut and open as if they weigh a ounce. So, I wiped off all the white lithium and used WD-40 on the hinges and the black piston type thing( I am sorry I have no idea what this part is called). Since the WD-40 is more of a liquid it enabled the hinge to move faster. Worked for me!
Old Mar 21, 2003 | 06:19 PM
02VQ35's Avatar
Problem with WD-40 is that it is a degreaser and sort of a desicant. The only thing I use WD-40 for is to remove glue and tape. I would recommend the White Lithium Grease, this is what Nissan uses and is available at any auto parts store. I got my WLG from my buddy he owns a bike shop so I got it free. Any sythetic grease would work great cause its more stable. Chris
Old Mar 22, 2003 | 08:26 AM
MaximaMoJo's Avatar
Yeah, I was using the white lithium in a grease form. I think the white lithium spray would be a different story. This would work better than WD-40, I only had the WD-40.
REDinLV
Aug 15, 2024 12:30 AM
trsandrew
Apr 8, 2016 06:45 PM
magiconthetire
Oct 26, 2015 09:03 PM
trsandrew
Oct 25, 2015 02:47 PM
lrb6805
Sep 24, 2015 05:03 PM
