How do I properly change my Auto Trans. Fluid?
Old Mar 20, 2003 | 03:44 AM
LouE37's Avatar
Is it just a matter of:
1) Warming up engine to idle temp.
2) Opening A/T fluid cap and remove drain plug
3) Replace drain plug and fill revervoir in engine bay
4) Recheck after 5 minutes of driving
5) Replace only the same amount that drains
If this is it then how would I do a complet flush? Any suggestions would be helpful. Also what tranny oil is good?
Old Mar 20, 2003 | 04:48 AM
PCGuRu2K's Avatar
Re: How do I properly change my Auto Trans. Fluid?
With your directions you would be doing just a drain a fill.. Remember since your auto there is a lot of fluid that gets stuck in the torque converter. I think like 1qt or less. Somewhere around there. The only way to do a complete flush is to take to a place that has the machine that will flush out your system with the new fluid.. Other then that your dir's will work for a drain/refill
Old Mar 20, 2003 | 05:02 AM
LouE37's Avatar
Re: Re: How do I properly change my Auto Trans. Fluid?
Cool thanks...i figure doing just a drain fill should be enough for a spring tuneup.
Old Mar 20, 2003 | 06:36 AM
CHIGGARMAX's Avatar
newbie questionS
while doing my oil change, i tried to locate drain plug but with no success.
does any1 know the size of the bolt?
do i need to replace the washer?
where do i fill the new aft?
thanks,
chiggarmax
Old Mar 21, 2003 | 03:32 AM
LouE37's Avatar
Re: Re: Re: How do I properly change my Auto Trans. Fluid?
Does anyone have a pic or can explain exeactly where the ATF drain plug is...looks like a needle in a haystack.
sctludwig
Sep 1, 2022 01:32 PM
pktaske
May 6, 2016 07:49 AM
captchaos
Mar 15, 2016 12:18 PM
pktaske
Sep 4, 2015 08:40 AM
dcardello
Sep 3, 2015 11:44 PM
