Window Vent Visors
Old Mar 20, 2003 | 08:59 AM
illmaxima's Avatar
Window Vent Visors
Have any of you removed window vent visors from ya max, and if so whats the easiest way to get them off the car?
Old Mar 20, 2003 | 09:10 AM
ms.thicknes's Avatar
Re: Window Vent Visors
a thin razor blade and goo gone go VERY VERY SLOWLY if you are trying to recyle the vent visors
and if you are not...then just yank them bad boys off and scrape of the double stick tape (CAREFULLY) using the blade....you can spray WD40 on the tape to loosen it up and use the goo gone to remove the sticky residue
good luck
Old Mar 20, 2003 | 11:52 AM
araffio's Avatar
I slowly pulled mine off and cleaned the window trim with goof-off
If I ver decide to put them back on (which I probably wont) I'll just remove the old tape and get new 3M double stick tape.
Old Mar 20, 2003 | 11:57 AM
95emeraldgxe's Avatar
spray around it with some goo-gone and let it soak in, and they should come off in a snap
Miket2006
Mar 1, 2021 03:55 AM
Fbana41
Aug 29, 2016 12:18 PM
lrb6805
Sep 24, 2015 05:03 PM
