Throttle body cleaning
Old Mar 20, 2003 | 09:14 AM
benolin's Avatar
Hey guys, my car is idling funny and having a hard time starting, so I'm cleaning my throttle body. I've never done it before and I'm always cautious when I'm unsure of what I'm doing. So, here's a stupid question. When I have the throttle wide open so the butterfly is parrallel, am I supposed to clean BEHIND that plate or just infront? Because the front, honestly is not so much dirty. Thanks. I'm in the middle of it now, so any help would be great.
Old Mar 20, 2003 | 09:33 AM
foodmanry's Avatar
Da Roller Coaster!
Re: Throttle body cleaning
Clean the entire butterfly valve and the surrounding outer rim of the throttle body. Basically clean as far as you can reach. You car will start kind of rough and might kick out some bad exhaust fumes, but after a little running it will run much smoother and perform better.
Old Mar 20, 2003 | 10:19 AM
njmaxseltd's Avatar
Use an old tooth brush and get in there as far as you can. Wipe it clean with a lint free cloth or good paper towels. Just make sure that what you stick in there, comes back out!
Old Mar 20, 2003 | 10:54 AM
WizzaMax's Avatar
best thing to do is unclip the plug on top of the TB and remove the four mounting bolts holding it to the manifold and completely swing the TB up and you can clean both sides and primary main runner part of manifold.
Old Mar 20, 2003 | 11:11 AM
benolin's Avatar
Thanks guys! That thing is firing up perfectly. That's amazing! Thanks again.
Old Mar 20, 2003 | 12:13 PM
ZeRo MaX's Avatar
yeah.. i gotta start cleaning mine too... is that the only thing to fix the idle?
Old Mar 20, 2003 | 01:09 PM
dm7297's Avatar
what kind of cleaner do you use?
220k+ A32
Sep 23, 2015 03:38 PM
bumpypickle
Sep 20, 2015 08:22 AM
97_GXE
Sep 15, 2015 06:47 AM
followthadollar
Sep 13, 2015 09:55 AM
Maxboy23
Sep 9, 2015 10:37 AM
