HELP!! stripped strut nut...
argh! freaking, nothing ever goes right. Well, haha this bolt was already stripped but I attempted to remove the bolt again. We used 14mm 12-point, 14mm 6-point, tried hammering a 13mm 12-point but coudln't get it in.
What's a good method of removing this stupid bolt?? Thanks guys. I am plannin on installing my FSTB, change brake pads (raybestos QS), paint calipers, rotate tires, blah blah blah...
Re: HELP!! stripped strut nut...
OR, try a vice grip, or there's this thing called nut-breaker you can get at the hardware store.
make sure you don't over torque that nut again! 35lbs..
o yeah, 1 more thing... about those 14mm nuts. Can I get the exact ones at a automotive store? I already went out and bought one from nissan but it freakin cost 1.70 per bolt. I want brand new ones for all of em because when I torqued the others back to 30lb... a couple of the other bolts' corners started to shave off.
Get a pick, put it an angle into the nut, and hammer it in there...after, just hammer it to loosen, and then pull it off...those strut mount bolts were a biznatch....had to buy new ones from the dealer as well....$11.xx for all 6
...i ordered em 3 months ago, still havent gotten my a$$ down there to pick em up
Originally posted by Jamsan
I would if you's accepeted something other than paypal..
or better yet.. PM kev to send him a MO and have him do it that way..
u hoes! whoring up my thread!! anywho freakin bolt still on. I hear that craftman sells something called "robo grip"... I think that was Chinkzilla was talking about. I will try to use the chisel method and see if i can get it loose that way.
Hey sprint, I was using penetrating oil on that nut lol
MaxLvr21
Oct 17, 2015 12:11 PM
maxima-junky
Oct 7, 2015 06:13 PM
RealityCheck
Oct 2, 2015 06:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
...*pm's Kev*
