Is it possible blowing your engine cleaning the TB?
Old Mar 21, 2003 | 07:08 AM
1MAX2NV's Avatar
When you sprayed down the butterfly, is it possible to use too much carb cleaner? The car won't start. Did I hydro locked it? I opened up the butterfly valve and sparyed some into the manifold too.
Old Mar 21, 2003 | 07:11 AM
Sprint's Avatar
i hope you didn't use carb cleaner.. and you used TB cleaner for Fuel Injected Engines
Old Mar 21, 2003 | 07:17 AM
1MAX2NV's Avatar
I used carb cleaner....so what should I do now?
Old Mar 21, 2003 | 07:23 AM
Sprint's Avatar
give it some time to dry out... that would be my guess for now.. maybe matt might have a better idea
Old Mar 21, 2003 | 07:47 AM
njmaxseltd's Avatar
Hold the throttle wide open when you crank it. (foot on the floor) It will start and throw out some nasty smoke. Might run a bit rough for a minute or two as well.
Old Mar 21, 2003 | 07:58 AM
MChapel's Avatar
Re: Is it possible blowing your engine cleaning the TB?
No need to worry about hydro-locking - unless you used about 1.5 litres of carb cleaner.
Old Mar 21, 2003 | 07:59 AM
DanNY's Avatar
Ad·min·is·tra·tor
you should be fine. just start the car like the engine was flooded...like Tom said.
Old Mar 21, 2003 | 08:18 AM
Matt93SE's Avatar
STFU n00b!
if it won't turn over at all, wait a few minutes and see if some of it evaporates. if not, then pull out the spark plugs, stick some rags/paper towels over the holes, and crank it over then. oughta blow the junk out, then put the plugs back in and drive away.
6spd4dsc
Mar 4, 2016 05:19 PM
crazyespn
Sep 3, 2015 01:30 PM
sdotcarter
Sep 2, 2015 09:53 PM
iflexsteel
Sep 2, 2015 08:04 AM
