OMFG ANOTHER STRIPPED BOLT... except its lug nut!!!!
Old Mar 21, 2003 | 04:20 PM
nadir_s's Avatar
vicodin ... gift of life
OMFG I CAN'T BELIEVE THIS!!!!!!! i stripped a lug nut!! how do i take this **** out??
Old Mar 21, 2003 | 04:29 PM
BC_95GLE's Avatar
Re: OMFG ANOTHER STRIPPED BOLT... except its lug nut!!!!
How do you do this man??????? Wow i have to admit i'm immpresed. Can't give you much help tho.
Old Mar 21, 2003 | 04:38 PM
Chinkzilla's Avatar
You need a new tool set. ALL hex deep socket craftsman or snap-on stuff.
The bolt-out set with a 21mm socket should work on your lug nuts.
Old Mar 21, 2003 | 05:03 PM
nadir_s's Avatar
hahah!!!! PENETRATING OIL BABY LOL
omg, i sprayed some of that crap on, then came up here made the post... then went back downstairs all sad and ****ed... so I decided to put all bolts on and just put the socket into taht stripped nut and began to take it off to test how much of it was stripped... it started to come off easy and at first i was like "damn, i stripped this ***** so bad..." then!! low and behold, the ***** fell off!! yay!! now time to go find me a new lug nut.
Can I ride w/ 4/5 lugs on? I searched and found it was ok for temporary use. lemme know!
Old Mar 21, 2003 | 05:53 PM
02VQ35's Avatar
The way I would take it off is go to Sears and buy one of those kits to remove stipped nuts and bolts. Second, If you need a standard OEM lugnut, I have 4 of them from a 99.5 SE-L that I'd like to get rid of cheap, email me if your interested. Chris
Old Mar 21, 2003 | 05:54 PM
Sprint's Avatar
I am riding on 4 on the right front.. and 4 on the left rear
Old Mar 21, 2003 | 07:06 PM
WizzaMax's Avatar
impact wrench to remove lugnut if needed
remove the wheel and all brake assembly
rotate the hub so the stripped bolt if lined up with the cutout behind the hub
with directed force, hammer the lugbolt out thru the hole
lightly lube the shoulder of the new lugbolt and hammer back in from the reverse
slip on several 1/8 " washers and torque open end wheel nut to about 100 ft/lbs
remove wheel nut and washers and re-istall brakes, wheel and torque lugnut to specs
Old Mar 21, 2003 | 07:10 PM
ZeRo MaX's Avatar
how do you strip a bolt.. (lug nut)
Old Mar 21, 2003 | 07:30 PM
foodmanry's Avatar
Da Roller Coaster!
Cross-thread it. Usually happens with someone using an impact wrench on the lug nuts. If anyone strips one by tightening it with a socket wrench, or the wrench from the tire change kit then they are numb nuts.
Old Mar 22, 2003 | 05:56 AM
Mishmosh's Avatar
That is how you strip the wheel stud threads. If you strip the lug nuts (the outside portion), I would question the tools you are using. Either the socket you are using is the wrong size or do not provide enough coverage over the lug nut.
Old Mar 22, 2003 | 06:39 AM
SG01MaxSE's Avatar
Dude... you REALLY need a torque wrench!
Old Mar 22, 2003 | 10:36 AM
nadir_s's Avatar
penetrating oil saved my *** lol... it loosened it like hell and the lug nut just slipped off.
I was using a torque wrench, but the nut already looked sorta stripped. As for the first bolt (strut nut), that's still on there stripped... I dunno how to take it off! blah, can't even install a simple mod like FSTB
Old Mar 22, 2003 | 10:44 AM
funmax's Avatar
get the new lug nut from the dealer and take your car to local mechanic have them loosen the nut.
Old Mar 22, 2003 | 10:48 AM
nadir_s's Avatar
yeah, how much do lugs usually run about? I wanted to get a couple... some of the nuts have taken a toll over the years.
I went out and bought a star to remove the lug nuts properly... the stock L shaped wrench wasn't working lol.
Old Mar 22, 2003 | 12:19 PM
Axel's Avatar
How much do lug nuts usually run? A few cents per lug nut (some will charge you a very high 50 cents/per which I find find outrageous! )
Old Mar 22, 2003 | 01:25 PM
BLaZin 2k MaX's Avatar
I would have got a tool bit that was alittle bigger then 13/16 and then put it ontop of the bolt and hammer then twist the thing off, iv had to use this method a couple of times, but never on my lugs.
coolsun
Wheels/Tires
Nov 13, 2016 05:01 PM
knight_yyz
Nov 1, 2015 01:34 PM
RealityCheck
Oct 2, 2015 06:34 PM
dcam0326
Sep 26, 2015 05:20 AM
