VQ35DE into a 4th gen?
Old Mar 25, 2003 | 12:03 AM
1NICEMAX's Avatar
Is it possible to swap a 2k2-2k3 engine into a 4th gen body?
Old Mar 25, 2003 | 12:26 AM
Jepht20's Avatar
Custom User Title...
no offense, but you're gonna get these soon ---> &
this has been asked many a time and i believe is in the faq's. i'd delete this before it gets out of hand. i believe you'll be told the gains are not worth the money, better off to turbo or supercharge. take it easy.
Old Mar 25, 2003 | 04:34 AM
max...to the ma's Avatar
yeah unless they create a turbo or supercharger for the 3.5 VQ (it'll come) then it will be a good investment. except how do u plan to get one in the first place? just curious of ur plan.
Old Mar 25, 2003 | 07:00 AM
T2CTeamShift
Wait
Forget the engine, read the FAQ's, its possible but its very expnsive, It would be better to get the 350z engine setup, and then if you have more money you could buy that TT setup they have for it. This is if you have enouph (MONEY Couph Couph) Just get a Turbo and crank some boost, If you have auto you need a VB Mod a Tranny Cooler and a TORQE Converter to get the most out of your car, or your gonna kill it fast
Old Mar 25, 2003 | 07:28 AM
stephenlc's Avatar
Re: Wait
If you are going to talk, know what you are talking about. He cannot use the a used 350z engine it is rear-wheel drive. He will have to get one from a max.
Old Mar 25, 2003 | 07:37 AM
dmontzsta
If you want to do engine swaps, buy a honda. Maximas are not hondas and we all have great motors, stock! The money you would put into getting a stock VQ35 into your Max, you could have a turbo'd or S/C's VQ30 cranking out more than that VQ35 might ever see.
Old Mar 25, 2003 | 07:38 AM
1NICEMAX's Avatar
OK OK DELETE THIS THREAD !!!
Old Mar 25, 2003 | 07:54 AM
Cumalittle
u knoe this from experience rite??? it's amazing how so many peep on this forum knoe so much about vq35 swapped into a 4th gen body that i have yet to see one successful swap...go MARDIGRAS!!!!
Old Mar 25, 2003 | 07:55 AM
MardiGrasMax's Avatar
If you can get the whole motor and ECU it would be doable, but in the few k$ range.
Old Mar 25, 2003 | 08:01 AM
Cumalittle
since we got the only guy here on the org that has the experience w/ the vq35 and vq30 i'll ask u...from wat u see...does the motor mounts from the vq35 motor seem to inline w/ the current mounting position on the 4th gen body???
Old Mar 25, 2003 | 08:12 AM
From what I have seen, yes. It looks like using the VQ30 mounts attached to the VQ35 block, the VQ35 will "bolt" right in to a 4g. Still yet to be proven, but I am betting on it.
Old Mar 25, 2003 | 09:43 AM
dmontzsta
Did I say it couldnt be done?
Read again...
I said for the money it would cost buying the engine, you could have a killer VQ30.
Old Mar 25, 2003 | 10:31 AM
Cumalittle
Read again...
wat if a person decides to go the n/a route vs. force induction??? i'm not trying to argue w/ u or anything...but my point was...many peep here on the org tend to believe if it wasn't made for the car then it won't work...when the question of motor swap comes up...yes i admit most of them are just far out of reach and very ignorant...everyones comes in and gives the typical answer...w/ the money anything is possible...it's not worth the money... blah blah blah...thas y all of the engine swap thread are crap...filled w/ typical answers...even flames then locked...and everyone goes on and say y don't u go do a search..it's been mentions millions of time..i think this is a fairly good example...vq30det...before that guy tilley or wateva his name is did his swap...everyone's answer was not worth the time or money...or the firewall needs to pushed out more cuz there's no room or wateva...then they go..for the money u can get a supercharger w/ better result...and w/ turboing a vq...prior to the two kit that came out...everyone was against it...they said it would cost to much...everyone was like...well if it was so easy to turbo a vq then y hasn't jwt or the bigger company made one yet?? blah blah bha...in the end...it was proven wrong...
Old Mar 25, 2003 | 10:49 AM
dmontzsta
you talk too much
j/p For N/A, it is the best way, I just cant see doing it, when boost is soo much funner.
Old Mar 25, 2003 | 10:55 AM
Cumalittle
you talk too much
hehe...i don't race anyway so it doesn't matter...i was just trying to make a point thas all...shiet...when i drive my car i hardly every shift beyond 3k...but when my engine decides to go...i will seriously look into vq35...
Old Mar 25, 2003 | 11:37 AM
jdmmax's Avatar
N/A cars are very fun.
i have experienced the NA power and its a beautiful thing and no it was not a domestic.
Old Mar 25, 2003 | 11:45 AM
Jeff92se's Avatar
I'm needing a caw
Actually if I had the choice of two engines: both V6 power
1) 280hp na ie.. 3.5VQ 350z engine
2) 280hp turbo ie.. let's say 3.0 VQ or 3.0 VE motor
I'd take the na power probably. Much more reliable and probably much better throttle response. Also I'd rather start at 280hp na and go from there vs trying to up the boost on a 280hp turbo motor already.
Old Mar 25, 2003 | 11:48 AM
Sprint's Avatar
what about the v6 in the Sentra.. i hear that one is pretty potent
dmontzsta
You are lying, you really want a VE-T.
Old Mar 25, 2003 | 02:00 PM
Jeff92se's Avatar
I'm needing a caw
MAXSE5SPD
Sep 17, 2022 04:00 AM
6spd4dsc
Mar 4, 2016 05:19 PM
VQ'ed
Forced Induction
Feb 29, 2016 08:05 AM
Violator
Sep 9, 2015 10:14 AM
Lowered_a33
Sep 1, 2015 07:49 PM
