SC Removal, no old stock parts, what is needed
Old Mar 26, 2003 | 10:58 AM
BrianV's Avatar
If my friend were to rip off his V1 SC Stillen Kit what parts would he need to be able to drive it properly? He doesn't have any of his stock parts anymore.
Obviously things like the intake are obvious, anything else?
Old Mar 26, 2003 | 11:34 AM
WizzaMax's Avatar
the part that has the oil return hose leading up to the blower below the camshaft position sensor needs to be put back on as a solid plate.
as well, the original tensioner assembly will be needed...as well as the proper length/thread/pitch bolts for the timing cover and original idler/tensioner pullies in the event the ones being taken off are the ASP or other metal types.
Old Mar 26, 2003 | 12:22 PM
ejj's Avatar
ejj
Power steering lines (I'd just buy new ones for the person that buy's the kit).
Old Mar 26, 2003 | 12:25 PM
BrianV's Avatar
damn more then I thought.
Old Mar 26, 2003 | 12:26 PM
ejj's Avatar
ejj
Doesn't the V1 use the stock tensioner?
[EDIT]
Also the V1 uses metal tension pullies...no need for ASP ones.
[/EDIT]
Old Mar 26, 2003 | 12:49 PM
dmontzsta
why is he taking it off?
Old Mar 26, 2003 | 01:57 PM
Confused's Avatar
Permanent Maxima.org Resident
don't forget the thermostat.. the modified thermostat housing is needed to fit under the blower.
Old Mar 26, 2003 | 03:14 PM
vbxmaxima's Avatar
Dont know if the v2 kit is much different, but
when I sent my blower back for rebuild, to keep running
I needed to find my old alternator bracket.
On the v2 kit the alternator now mounts on the sc bracket.
Old Mar 26, 2003 | 03:48 PM
ereet's Avatar
Confused beat me on the thermostat mention =/ .. If you plan to resell the kit, you'll probably need to either get new hoses for the power steering to include to a wanting-buyer, or replace the current ones.
The oil-T-adapter was said .. and um. Oil drainback plate. You'll probably have to get a stock one or plug the one you have (assuming you're not reselling) Thermostat/power steering/oil line/oil drainback is all the fluids I can think of.
smplyamzng
Dec 13, 2015 01:19 PM
schmellyfart
Sep 25, 2015 04:47 PM
TonyJr
Aug 20, 2015 12:14 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
kirkhilles
Aug 8, 2015 10:53 AM
