Strut Bar Install
Old Mar 26, 2003 | 03:00 PM
Chupacabrą
Strut Bar Install
I don't know if you have talked about this before...but
Did any onf you install your strut bars yourself? I tried and tried and tried, and those bolts would not budge. So I went to Big 10 Tires, and got a tire guy to use that air gun for $5
Old Mar 26, 2003 | 03:30 PM
Lordrandall's Avatar
If they were so tight you needed an air gun, they were way too tight.
IIRC, they are only supposed to be tightened to about 47 ft. lbs.
Old Mar 26, 2003 | 04:03 PM
Jamsan's Avatar
Even less than that ....
Shoulda just bought a socket wrench with no ratchet (doesn't click and spin both ways), and then coulda just pulled as hard as you wanted without having to worry about breaking the wrench
Old Mar 26, 2003 | 04:13 PM
Chupacabrą
dang, what happens when they're too tight?
Old Mar 26, 2003 | 04:30 PM
Asian_N02's Avatar
if they are too tight...you can snap the bolt...that's a no-no!!! Torque it to around 30lbs and you will be fine...
Old Mar 26, 2003 | 05:06 PM
djPlayboy's Avatar
I torked mine to 35, also I did break a socket trying to get the nuts off then busted my but when it broke...lol
Old Mar 26, 2003 | 07:07 PM
A33 VQ30DEK's Avatar
try using a breaker bar... alwayz helps
Old Mar 27, 2003 | 05:16 AM
Lime's Avatar
the manual I have indicates 35-50 ft-lbs of torque on those bolts; it's not that much.
Old Mar 27, 2003 | 12:34 PM
nadir_s's Avatar
vicodin ... gift of life
after you've got your FSTB installed and torqued to 30lb, give it a week to "settle-in" then go back and check on all the bolts and re-torque them to 30lb.
Old Mar 27, 2003 | 12:35 PM
Chupacabrą
how much is a tourque wrench?
Old Mar 27, 2003 | 12:36 PM
nadir_s's Avatar
30 bucks for a good one. it is definately a helpful tool, and if you plan to work on your car (do regular maintenance on it yourself), it is a handy tool.
Old Mar 27, 2003 | 06:14 PM
JoesMAX's Avatar
be careful not to bust a nut
Old Mar 27, 2003 | 07:05 PM
spiff56747's Avatar
thats what i thought when i saw
Old Mar 27, 2003 | 07:23 PM
JoesMAX's Avatar
lol thats what made me think of that
Old Mar 27, 2003 | 07:27 PM
99Maxima5sp's Avatar
, hopefully mine will be ALOT easier to install. Just ordered one off ebay.
eric
Old Mar 27, 2003 | 07:50 PM
JoesMAX's Avatar
eric
its a simple install, i wouldnt worry about it
lowpost99
Oct 26, 2025 06:53 PM
matts95max
Apr 23, 2025 10:44 AM
BkGreen97
Apr 2, 2016 05:47 AM
dvcamp
Sep 18, 2015 10:17 AM
Johnny9595
Sep 3, 2015 05:18 AM
