AXLES- how to tell between auto/5speed
Old Mar 27, 2003 | 02:50 PM
Nismo's Avatar
Im going to be buying some manual axles soon for my 5sp conversion so I wanted to know how can I tell if I recieve 5sp ones? are they marked on them so that you can know if you have the correct ones? I just dont want to end up finding out that I recieved auto ones inbetween the install thats all.
Old Mar 27, 2003 | 03:08 PM
md53's Avatar
Re: AXLES- how to tell between auto/5speed
The passenger side is the same, but the drivers is different. I'm not sure how to tell unless you put them side by side. The manual is a little shorter(or longer) but it is different.
Old Mar 27, 2003 | 11:09 PM
96shogunmax's Avatar
Re: Re: AXLES- how to tell between auto/5speed
This is what the 5spd axles look like. Sorry it was taken with a sprint phone.Good Luck
Old Mar 27, 2003 | 11:19 PM
Ramius83
The driver's side 5-speed axle will be longer than the automatic one....
Old Mar 28, 2003 | 12:26 AM
Nismo's Avatar
ic, thanks for the pic. But, is there a way to tell because I still have the auto axles on the car so its hard to put them side to side to compare.
Old Mar 28, 2003 | 11:58 AM
Dreizehn's Avatar
Here is a pic of the auto axles... I don't know if you'll be able to tell a difference between the two or not...
Old Mar 29, 2003 | 12:49 AM
Nismo's Avatar
thanks for the pic. Im still unshure if I should buy both axles or not. anyone that has done a 5sp conversion know for shure if both axles needs to be swapped? I dont want to spend unnessisary money if I only need to buy one.
Old Mar 29, 2003 | 06:25 AM
Iron Lung's Avatar
just buy the driver's side
Old Mar 29, 2003 | 12:02 PM
irvine78's Avatar
they're exactly the same....auto/maunal...there's no difference...when i had to replace my driver side axle, the shop didn't have any for the 00...but, the shop did have a 97 AUTO axles(both driver/passenger) and i tried them....they fit exactly the same!! so i tried on the passenger side...they were exactly the same too!!
Old Mar 29, 2003 | 02:42 PM
Nismo's Avatar
thats weird. now im really confused now since some say its different and others say its the same yet when I look at some sites they ask weaither you want auto or manual axles.
Old Mar 29, 2003 | 03:38 PM
Iron Lung's Avatar
While I was doing the conversion, I seem to recall that the drivers axle was only slightly off. It would fit in but add additional stress to the bearings.
croser2
Feb 24, 2008 10:45 AM
BlackBIRDVQ
Mar 19, 2007 08:52 PM
