Adding a shock sensor to factory alarm.
Old Mar 27, 2003 | 07:04 PM
drjohnnyfever's Avatar
A while back I saw an editorial or something about adding a shock sensor to the factory alarm. Could somebody refresh my memory on where to find it? TIA
Old Mar 27, 2003 | 07:18 PM
clee130's Avatar
http://forums.maxima.org/showthread....t=shock+sensor
But the article on Russ's site is no longer available due to 5thgenmaximas.com no longer being up and running.
Old Mar 27, 2003 | 07:29 PM
99Maxima5sp's Avatar
deifnately interested in doing this myself...
eric
Old Mar 27, 2003 | 07:43 PM
I found the on I saw before here it go
Glass and Shock sensor to your Factory Theft deterrent system
Old Mar 27, 2003 | 09:15 PM
95emeraldgxe's Avatar
you could get a decent alarm installed for about 150 bucks with those features included, i think that would be a better alternative - you will also recieve about 10-15% off on your insurance
Old Mar 28, 2003 | 04:51 AM
I can add a shocksensor for about 10 bucks and I already get a discount for having the factory alarm.
Old Mar 28, 2003 | 08:22 AM
ny96max's Avatar
unless you had an aftermarket system installed by your dealer, you DO NOT HAVE a factory alarm. Its a keyless entry system with horn honk and door trigger, lol.
Ant
Old Mar 28, 2003 | 08:24 AM
gtr_rider's Avatar
192.168.1.1
http://www.max-world.org/5thgen/how-...ocksensor.html
Old Mar 28, 2003 | 11:12 AM
DAREN's Avatar
Ant
i think that the 95/96 maxima's do have a factory alarm. if you lock the car. with a window/s open let it sit for 2 minutes. after letting it sit reach inside the door and use the unlock button or open it yourself manually. fi the horn and lights go off you have a factory alarm. like any other alarm it wont prevent people from stealing items inside the car but it will make it difficult to steal the car itself. they will not beable to start the car until you put a key in the door and unlock the car.
Old Mar 28, 2003 | 11:46 AM
KsuMax's Avatar
Cheesing away...
I have a 96 with a factory alarm. It does everything that DAREN explained. The alarm also goes off if you arm it and try to open the engine bay. I need to hook up a shock sensor to it though.
Old Mar 28, 2003 | 12:00 PM
Asian_N02's Avatar
here is an old link I had...
http://www.rcreations.com/public/CoD...e,0t,P=30.html
Old Mar 28, 2003 | 05:23 PM
Yeah thats what I thought, I would call it more of a theft detterent system but if you add a shock sensor or a glas break detector, not sure of the exact name I don't se why it would be any different than any other system. It has ignition shutoff, door sensors, if you add a quality shock sensor, glass sensor and maybe a siren how much different would it be from any other alarm?
Old Mar 29, 2003 | 12:10 AM
ny96max's Avatar
like i said its a keyless entry system with horn honk, parking light and door driggers wired up to it. I know cause my car came with it also. When i installed my "alarm" i did not have to bypass anything, cause keyless enrty doesnt not arm itself automatically or cut off the starter, whereas my new alarm does all of the above and more
Ant
Old Mar 29, 2003 | 10:03 PM
DAREN's Avatar
Ant
right and wrong.
it does not arm itself automatically but it does kill the starter if it is triggered, via the doors. the hood and trunk work in the same fassion. you can test them by leaving them open and then arming the alarm. thats how the sytem worked on my VE and i am pretty sure it the same on my (early) VQ.
why do you think people who have cheaply/poorly installed aftermarket systems have troulbe starting their cars. the actuators/switches that are used to unlock the doors trigger the factory alarm. they stand their clicking the key fob (aftermarket) like mad and the car wont start and the factory horn is blowing synchronous with the lights. i have witnessed this several times and got a good laugh, or even better; i helped them disable it by turning the key in the door lock. as far as i know a good installer will disable the factory systerm when you get an aftermaket 1.
MaxLife17
Jun 27, 2019 01:37 PM
Vistance
Sep 17, 2015 05:17 AM
Stagnet04
Sep 14, 2015 11:28 PM
