Stillen Oil Cooler question
Old Mar 27, 2003 | 07:57 PM
delio's Avatar
Does anyone with a Stillen oil cooler know the size of the fittings that it uses on the lines?
Thanks,
Del
Old Mar 27, 2003 | 09:09 PM
bill99gxe's Avatar
Evil Administrator - "The Problem"
Do these help?
http://forums.maxima.org/showthread....cooler+fitting
06AN?
http://forums.maxima.org/showthread....2FC+oil+cooler
Old Mar 28, 2003 | 06:35 AM
delio's Avatar
Bill, these are referring to permacool, and I am not certain that Permacool's setup and Stillen's setup are similiar in that respect. I too searched and didn't come up with a answer specifically relating to the Stillen kit, with their "no-name" filter sandwich adapter, and unidentifiable cooler.
Anyone else?
Old Mar 28, 2003 | 06:55 AM
bill99gxe's Avatar
Perhaps $tillen sucks or is overpriced and everyone went with Perma-cool?
In reality, Keving could answer your question in 2 seconds but is choosing not to right now.
Old Mar 28, 2003 | 06:56 AM
Y2KevSE's Avatar
Rice Boy in Denial =)
I used -8 lines... -8 120 degree bend fittings off the sandwich adapter (probably 1/2 NPT)...
You need to find out what the fittings are for the cooler.
Old Mar 28, 2003 | 06:57 AM
bill99gxe's Avatar
Old Mar 28, 2003 | 07:21 AM
delio's Avatar
That's what I am trying to do... hahahaha... you know why
Old Mar 28, 2003 | 07:24 AM
delio's Avatar
Bill in regards to Stillen Vs. Permacool, your absolutely right, I got by Stillen
I don't think Keving has the answers, but maybe he should give me the link to his Permacool kit so I can get that instead.
Old Mar 28, 2003 | 07:26 AM
Y2KevSE's Avatar
Originally posted by delio
I don't think Keving has the answers, but maybe he should give me the link to his Permacool kit so I can get that instead. ;-)
Rubber hoses?
Old Mar 28, 2003 | 07:48 AM
delio's Avatar
Rubber hoses?
No I need to make sure I get the right Sandwich adapter If I am going to swap coolers.
Old Mar 28, 2003 | 08:01 AM
Y2KevSE's Avatar
Mocal 180 degree F thermostat build into the sandwich adapter.
Old Mar 28, 2003 | 08:10 AM
delio's Avatar
jOo got links? gimme more info. I need to order this stuff ASAP. What fittings and stuff did you get for the cooler? I think I am going to go with the dual cooler and do the PS as well, makes things a little cleaner under there.
Old Mar 28, 2003 | 08:14 AM
Y2KevSE's Avatar
PS? That is probably an overkill since you already have aluminum lines for it.
http://www.racerpartswholesale.com/mocal.htm
Excerpt from http://forums.maxima.org/showthread.php?threadid=187943
Originally posted by JAY25
wish I was in Cali to work on that beast and get it done. My car was down for 2.5 weeks I cant picture my car been down that long.
By the way where did you get the fittings to fit your Oil cooler? I would like to do that with the stainless steel lines, looks very neat and no mess, These rubber hoses just aint cutting it no more.
I bought the fittings from a local shop, but I can give you the Aeroquip part numbers. Rubber hoses suck!
4 FCM2008 -8AN flare 1/2 NPT
2 FCM1013 -8AN hose ends (you may want to locate a good spot for the cooler before buying these)
2 FCM1043 -8AN 120 degree hose ends
Old Mar 28, 2003 | 08:19 AM
delio's Avatar
Aluminum? Huh? Mine are rubber, going to the aluminum U shaped tube, coming back out as rubber. I have the hard alumium lines going into the Pump if I am correct, but not going to the cooler.
I would like to do everything in SS, but I need to mail order everything since I don't have ANY decent tuner shops around here.
Old Mar 28, 2003 | 08:24 AM
Y2KevSE's Avatar
Yeah, I was talking about the aluminum U tube. Gotcha... you want to go all out bling bling and do SS lines for everything. I thought about but my hands/fingers said no from being pricked so many times.
The PS hoses look to be -6... can't use hose ends on the plastic reservoir but you can use straight ends on the new threaded cooler (or 90 degree hose ends... depends how you're mounting it).
Old Mar 28, 2003 | 08:33 AM
delio's Avatar
Which size?
Old Mar 28, 2003 | 08:39 AM
delio's Avatar
I am not sure if I am going to do SS for the PS, but it would be nice, although if not properly held down, would prolly rattle like a ****.
I have the issue now with the Oil Press guage, the SS line for it rattles to high hell. I am going to buy stock in a zip tie company.
Old Mar 28, 2003 | 09:25 AM
Confused's Avatar
Permanent Maxima.org Resident
Oil coolor for sale?? oints to del's avatar:
Old Mar 28, 2003 | 09:26 AM
delio's Avatar
Hahahahahaha!!!
Old Mar 28, 2003 | 10:02 AM
Y2KevSE's Avatar
20mm
Old Mar 28, 2003 | 10:43 AM
delio's Avatar
Did you use a B&M tranny cooler or did you buy a kit and throw all the junk out?
Old Mar 28, 2003 | 10:48 AM
Deac's Avatar
Hmmmm
Del,
The Stillen & Permacool oil coolers help to keep your oil cool. Hope this helps!!!
What the heck is all this about anyway!!! What are you up to?!?!? PM me...
Deac
Old Mar 28, 2003 | 10:53 AM
delio's Avatar
Re: Hmmmm
Originally posted by Deac
Del,
Deac
D,
I have had the stillen cooler for over 2 years now
I am looking to go to a dual pass cooler to clean up the routing of the lines, and I want to get away from the rubber lines to Stainless steel lines for some more show appeal (Bling Bling) So I am considering switching from the Stillen kit that I already have to a different, obviously custom setup and I need to pester Keving for some more info.
Old Mar 28, 2003 | 11:06 AM
Y2KevSE's Avatar
Bought a B&M cooler and boxed the PermaCool kit.
Old Mar 28, 2003 | 11:09 AM
redmaxpa007's Avatar
i SeE what you did therE
good choice
Old Mar 28, 2003 | 11:11 AM
delio's Avatar
OK I know I am becoming a PITA... where did you get it...
hahahaha
is it a tranny cooler or specifically for motor oil? does it even matter? I want to be blingin like you Keving
Old Mar 28, 2003 | 11:16 AM
hahahaha
how did you ever install your stuff yourself???
sigh..
www.jegs.com
Old Mar 28, 2003 | 11:39 AM
delio's Avatar
sigh..
www.jegs.com
There's a polished one on that site? No but there is in Kevina's car, so either he bought it that way or paid for the bling bling, that's what I need to know.
Thanks Pinky
Old Mar 28, 2003 | 01:52 PM
Deac's Avatar
Re: Re: Hmmmm
D,
I have the Stillen one that will be installed next week... dont know exactly how it will work but we replaced the stock rubber lines w/SS ones already...I'll let you know how it goes.
Deac
Old Mar 31, 2003 | 11:28 AM
Y2KevSE's Avatar
Thanks Pinky
Yes, there is a polished one on the site... didn't pay bling bling for it.
130-70265 Supercooler 15,000 GVW (11''x 4.5'' x 1.5''), Polished Aluminum, (2)
Old Mar 31, 2003 | 12:32 PM
delio's Avatar
Took you long enough... your wrist still limp? err I mean sprained
Old Mar 31, 2003 | 01:16 PM
Y2KevSE's Avatar
:slap Took you long enough... your wrist still limp? err I mean sprained :007
Yeah... too much 'ing in SF.
Old Mar 31, 2003 | 03:08 PM
bill99gxe's Avatar
I'm getting vuja de:
http://forums.maxima.org/showthread....ighlight=70265
Get the 70255 if you don't want to custom do the fittings......
Old Apr 1, 2003 | 07:10 AM
Y2KevSE's Avatar
He wants bling bling.
kjlouis
Oct 3, 2015 05:29 AM
Maxboy23
Sep 9, 2015 10:37 AM
Maxboy23
Sep 4, 2015 06:04 PM
Johnny9595
Sep 3, 2015 05:18 AM
sdotcarter
Sep 2, 2015 09:53 PM
