Clutch pedal holding too much pressure
Old Mar 29, 2003 | 01:53 PM
96shogunmax's Avatar
Since I got the coversion done I have noticed that everyonce in a while I have to get out of the car and crack the top valve to let pressure off of the line, because the pedal has built up to much pressure and makes the pedal very very stiff and also when you put shift into 2nd and get on it , the clutch seems to slip because of this built up pressure. After I crack the line though, everything is normal, no slippage or anything. I have been told that it is the pedal adjustments, but I have been playing with the adjustments for 2 weeks now. Any advice?
Old Mar 29, 2003 | 02:47 PM
Re: Clutch pedal holding too much pressure
ttt
Old Mar 29, 2003 | 11:26 PM
Re: Re: Clutch pedal holding too much pressure
Old Mar 30, 2003 | 01:36 AM
Turbo95Max's Avatar
Turtle turtle... Moderator
yea i believe it has to do with your pedal adjustment because i had this prob before and i know other people that have had it as well.
Old Mar 30, 2003 | 01:46 AM
Nismo's Avatar
what was the solution? I read on HLH0501's site saying theres some washers that bolt to the master cyl. was that it?
Old Mar 30, 2003 | 10:33 AM
cbr2's Avatar
Re: Re: Re: Clutch pedal holding too much pressure
Originally posted by 96shogunmax
yup... The factory set-up has a big spacer between the firewall and the pedal.. If you did not oul some sorta spacer back then your cylinder is adjusted totally wrong.. and when you let off the pedal the plunger part of the cylinder is not returning back far enough to allow the fluid to move back properly.. You need to lay on your floor and adjust the plunger by turning the little bar that attached to your pedal.. you will need to screw it so that the bar travels toward the rear of your car (i think in screw it in)...
Old Mar 30, 2003 | 04:32 PM
Re: Re: Re: Re: Clutch pedal holding too much pressure
Already did this. I bled the clutch again today. So far so good.
Old Mar 30, 2003 | 05:55 PM
matt calder's Avatar
I had the same problem when I had my ACT clutch installed and I got rid of it by replacing my Clutch master cylinder. Havent had any probs for 3 weeks now. Before I would only be able to drive 10 minutes or so in stop and go traffic before I had to relieve the pressure again.
Old Mar 30, 2003 | 09:55 PM
I have a brand new one. I installed this when I did my conversion.
Old Mar 31, 2003 | 05:52 PM
Nismo's Avatar
did you put in those spacer things between the master and firewall as mentioned above? if so what did you use? or did you buy them at the dealer? part#? I think I need them
Old Mar 31, 2003 | 05:59 PM
No spacer things, but there is a plate b/t them. I adjusted the rod some more today and its doing well now. Just adjust the rod from the Master cylinder to the pedal. Take it way back.(towards the rear of the car)
Old Mar 31, 2003 | 06:12 PM
Nismo's Avatar
Re: Re: Re: Re: Re: Clutch pedal holding too much pressure
ok I see what you mean. wonder what the spacers are really for then if you didnt need them.
Old Apr 1, 2003 | 01:20 AM
Turbo95Max's Avatar
you wasted your money on a clutch master cylinder Matt!!! your prob went away cause you changed the adjustment when you put in the new master while you coulda saved yourself alot of time and money if you juss did the adjustment. hehehe
Old Apr 1, 2003 | 11:41 AM
Old Apr 1, 2003 | 03:59 PM
Well I didnt buy a new one, actually bought a used one off of here. Its kinda ironic how this came up after I swapped them. Oh well you live and learn.
Old Apr 1, 2003 | 11:04 PM
Im going to a manual transmission shop tomorrow to get this fixed.
Old Apr 6, 2003 | 06:37 PM
Didnt go, fixed it myself. Problem solved.
user 11122324
42
Jul 18, 2022 03:35 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
