Ground Control Coilover Question (Strut Bearing)
Old Apr 3, 2003 | 07:04 AM
ejj's Avatar
ejj
What (if anything) do you guys with GC's do about the strut bearing when lowering the car off a jack/stands?
Because the assembly is so short, there's a good bit of space between the bearing and body of the car until its back on the ground. If the bearing isn't lined up happy, it won't go into place properly until you drive a bit and it pops back in there.
I've considered using grease to stick it to the body, but don't know if that's a great idea.
Because of this I've ruined both of my bearings and need to replace them, and would rather not do this once a year if I can help it.
Old Apr 3, 2003 | 07:51 AM
Dreizehn's Avatar
Re: Ground Control Coilover Question (Strut Bearing)
I've done the grease trick. I think I've done it the same as you, put grease on the bearing and let that hold it in place in the upper seat, while you lower the car. That is the best way I've found, but I have replaced it more than once prior to trying this. What problems have you had with doing this?
Old Apr 3, 2003 | 07:53 AM
ejj's Avatar
ejj
Re: Re: Ground Control Coilover Question (Strut Bearing)
Problem replacing the bearing? None. Just a PITA I'd like to eliminate if I could.
Old Apr 3, 2003 | 08:21 AM
Dreizehn's Avatar
Re: Re: Re: Ground Control Coilover Question (Strut Bearing)
The grease trick works. I know what you mean about replacing the bearings. Everytime you have to replace them, you need an alignment. Another reason for them being a pita...
By using the grease it's sure to stay there and sit right when you lower the car. The last time I replaced one, the old one was a mangled mess from not sitting right, basically flattened it.
Good luck.
Old Apr 3, 2003 | 08:25 AM
ejj's Avatar
ejj
Re: Re: Re: Re: Ground Control Coilover Question (Strut Bearing)
I suppose I was hoping for a neater, nicer solution. I guess it will do.
Old Apr 3, 2003 | 08:32 AM
Dreizehn's Avatar
Re: Re: Re: Re: Re: Ground Control Coilover Question (Strut Bearing)
Sorry, I don't know of one, unless you have that aluminum "top hat" milled so the bearing sits on there more firmly. That is part of the problem...
Old Apr 3, 2003 | 09:31 AM
matt calder's Avatar
I have replaced 4 of those now. The ones I am riding on now are messed up too. They have been messed up for awhile now and I havent really had any problems, just a little squeaky noise every once in awhile.
I thought about gluing it to the mounting plate thingie instead of sitting on the coilover but dont know if that would work.
Old Apr 3, 2003 | 09:33 AM
ejj's Avatar
ejj
I would think that would prevent them from functioning as designed.
Old Apr 3, 2003 | 10:09 AM
Dreizehn's Avatar
If you look at the bearing itself, there are two plastic pieces with grease inbetween, that slide separate of one another. You could glue one side the bearing to the mounting plate...
Should still work as designed...
Old Apr 3, 2003 | 11:56 AM
exactly, because the way it is now, that little raised ring around the circle always get torn up.
Old Apr 3, 2003 | 07:30 PM
Nealoc187's Avatar
SLOW
I tried supergluing mine to the bottom of the strut mount, but there was too much corrosion and it wouldnt hold. Basically I just lower it very slowly with my hand in there holding it in place as best I can and try to feel that it's being lined up straight. I end up replacing them every year. Going to the track every week and jacking the front up all the time takes its toll. They are torn up right now and squeaking a little.
95Maxi
35
Sep 2, 2015 10:37 AM
FanaticMadMax
Aug 10, 2015 08:55 PM
laparka66
Aug 6, 2015 09:36 AM
