Different Spring Rate for JIC suspension!!!
Originally posted by Y2KevSE
They can be, so when someone bottoms out with this setup, we have to ask if he/she adjusted via the perch. You obviously know what you're doing so I know you didn't lower via the perch.
thx
Originally posted by MaxTuner
Do you have to take out the strut body bolts at the bottom to adjust the ride height after the coil-over has been installed? because the rear ones, I think you can just twist it to adjust while it's bolted on the car? Yes or no?
thx
thx
Originally posted by Y2K2Driver
You don't have to remove the struts to adjust them. Just loosen the bracket locking ring. This will allow the strut body to turn in the mounting bracket. If you want to raise the car, you use the smaller of the two wrenches to turn the strut body by leveraging against the locking ring of the spring perch. Turn it like you are tightening the ring. To do the reverse, use the larger of the wrenches and turn the spring perch as if you are trying to lower it. In both cases, the other ring will prevent it from moving and instead just turn the strut body, lengthening or shortening the strut body in the process.
thx
ugh I ran over a brake rotor today.. (WTF)
made a big THUNK
pulled over to check for damage, none visable. I think I may have bent a rim though even though I can't tell visibly or by the ride.
At least I didn't fly off the road.
made a big THUNK
New springs on the way
We had JIC ship you a softer set of springs 8k and 5k.
Anything softer and/or helpter springs is not the answer and based on the weight of the car to soft and would be dangerous.
You will see the new springs on Tuesday.
Regards
Regards
Re: New springs on the way
Regards
Regards
Regards
Regards
This is the first time any aftermarket company has done that, unlike companies like Stillen (who doesn't care if you kill yourself even though it's their design flaw)
Anyhow, I will try this setup to see if it satisfies me.
Tim
Re: Re: New springs on the way
Appreciated your help, Paul, I guess we were all surprised what JIC did in terms of banning people from buying what they wish to get!
Tim
Tim
hmmmm juss wondering whats going on. Im riding my 2k2 on JIC's now too..at 9 front 8 rear. So far no bottoming out with 5 people on the car at the same speed and location kevin drives (fast lane of 880 south) Ive hit several bumps that used to bottom out my stock suspension with this many people. but wiht the JIC's its oooooookaaaaayy
The bumps right after Alvarado-Niles exit, before 84 east, and a little before 237.
My Stage 2 SFCs make my ride very stiff and abrupt over those bumps (uneven road levels).
I'm thinking about getting JICs in the future, anyone wanna give me a ride some time this summer?
the 237 one they look like theyre kinda fixing the the last one still feels like it sends my car airborne.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
