Variable intermittent wiper doesn't work.
Old Apr 3, 2003 | 09:13 PM
Wizeguy's Avatar
A friend of mine has a 96 SE with stock basic wiper stalk. The variable setting doesn't work. It goes
off
off
normal
fast
He's picked up a variable stalk and installed it. It still doesn't work. Any thoughts?
Old Apr 3, 2003 | 09:17 PM
Ramius83
Well, the actual variable portion on it is when the wiper is on the first setting. Tell him/her to turn the outside dial to the shortest "marks" and to turn the wiper on one position down. See if this works. The actual variable settings is only for the 1st position.
Old Apr 3, 2003 | 09:21 PM
Wizeguy's Avatar
Yes you are correct. With the basic non variable unit if you turn it on it should quickly swip... then pause... then swip... but nothing.
The new variable unit does the same thing. In the variable setting it does nothing...
The variable setting is like the dixey chicks. Useless and just taking up space...
Old Apr 3, 2003 | 09:51 PM
Ramius83
Huh, so you are saying that it isn't even working? Well, if so, and you are sure it is not working, then it is defective. I have replaced two, one 96 and one 98, wiper stalks from the stock non-variable switch to the variable one and both have worked flawlessly. I would say it is defective. Probably, the rotary switch in the variable switch is defective, rendering the whole thing useless.
Old Apr 3, 2003 | 10:03 PM
Wizeguy's Avatar
The stock switch and the one he just purchased both bad? I'd hope his luck is better then that.
Wizeguy - Watch out for that bus! What bu...
Old Apr 3, 2003 | 10:04 PM
Ramius83
If you have a 95, try plugging yours in and see what happens. If it doesn't work, then he is SOL....
Old Apr 3, 2003 | 10:40 PM
Wizeguy's Avatar
I do and would love to. He's 300 miles away. Bummer
Old Apr 4, 2003 | 12:25 PM
Wizeguy's Avatar
anyone?
fx4five
Oct 18, 2015 06:57 PM
BobTX10
Oct 7, 2015 08:43 AM
fx4five
Oct 1, 2015 04:58 AM
leatherneck
Sep 30, 2015 09:16 PM
Kyle Lee Cleveland
Sep 28, 2015 07:58 AM
