My VG super Charger..
Old Apr 5, 2003 | 08:32 PM
LeeIt2Me's Avatar
Well, Did my homework and I head to the machine shop and this is what I came home with. Soon to be super charger VG max. It's still early stages of testing and fitting. So, don't flame on how to do this or do that. Will update as I progress on this project.
http://www.cardomain.com/id/leeit2me
Old Apr 5, 2003 | 08:35 PM
Sprint's Avatar
good luck .. you seem to have your head on straight. People don't flame you if you seem like you are serious and are moving forward
Cumalittle
Re: My VG super Charger..
Old Apr 5, 2003 | 09:05 PM
gtr_rider's Avatar
192.168.1.1
Wow, cant wait.
Old Apr 5, 2003 | 09:11 PM
krismax's Avatar
Father of the 00 VI
Thats what needs to be done more offen
Old Apr 5, 2003 | 09:52 PM
Jon91SE's Avatar
Pusssseeeehhhh
Are you kidding me!
Old Apr 6, 2003 | 12:38 AM
NixMaxGLE's Avatar
daaaaamn. good luck man. vg power.
Old Apr 6, 2003 | 01:22 AM
MaximaGXE93's Avatar
Good luck
Old Apr 6, 2003 | 03:44 AM
redmaxpa007's Avatar
i SeE what you did therE
have fun..
Old Apr 6, 2003 | 05:24 AM
LeeIt2Me's Avatar
Thanks guys for the support.
It's going to be fun once its all said and done.
Old Apr 6, 2003 | 05:37 AM
Black VQ's Avatar
What kind of setup will it be?
I don't hang out in the 3rd gen forums, so I don't know if perhaps the Frontier/XTerra Roots blower could be retrofitted with some work. That idea just popped into my head when I saw "VG Supercharger."
Whatever you're doing, keep us posted!
Old Apr 6, 2003 | 10:57 AM
AscendantMax's Avatar
good luck man. glad to see some serious work done on the VG. Keep us posted
Old Apr 6, 2003 | 11:07 AM
BC_95GLE's Avatar
Good luck..
Old Apr 6, 2003 | 11:40 AM
Maximan190's Avatar
nice, someone who talks and does instead of someone who talks only.
Old Apr 6, 2003 | 02:28 PM
just wondering, how much boost are you trying to achieve from the supercharger once you get it running?
Old Apr 8, 2003 | 10:47 PM
kingcarnage's Avatar
WOW AN ENGINEER!!
Thank god for someone who at least tries to do things right. I can see you have some idea what you are doing. Here are the main issues I see:
1) are you getting enough wrap off of that belt to eleminate slip?
2) are you going to change to a carburated intake, because if not then you need to have the computers lookup tables re-generated in order to handle the change in operating conditions. (When the manifold pressure is high the computer will think the engine is at low load and give the wrong injection quantities and times. Thus is why forced induction is often not as effective on fuel injected engines)
if you already know all of this then I am anctious to hear what solutions you have if any.
Old Apr 8, 2003 | 11:26 PM
DA-MAX's Avatar
Eat, sleep, and sh*t 2JZ
Re: WOW AN ENGINEER!!
huh!?!?! you're thinking WAAAAAAAAAY too hard! majority EFI engines made today are perfectly suitable to run forced induction to a certain limit...the secret prety much is fuel and ignition manipulation. by either minor piggy back equipment(AFC, FMU, etc.) or a total ECU reprogram..."switch to a carb", thats the first time I've ever heard that
Old Apr 9, 2003 | 01:03 AM
MaDMaX024's Avatar
our motors are run by MAF sensors, not MAP. since i dont know much about MAP, i'd assume thats what you're referring to with the whole manifold pressure thing.
someone shoot me in the foot if we do infact have MAP sensors in addition to MAFS.
Old Apr 9, 2003 | 06:33 AM
LeeIt2Me's Avatar
As for how much boost will it produce? That has to be determine when I put a boost gauge on it.
For the Belt Slippage? right now without out the grooves on the pulley it's going to slip I know that for sure. Once I get it mounted and test running and know that I am sure it will stay put, then I will have to machine out a pulley with grooves the get more surface area on the belt and pulley. And I can machine out bigger or smaller pulley anyway.
Well, for how I am going to control the fuel and air? Hmm.right now I am just going to slap a FPR or FMU like the guys with S/C on it and see from there. If I have too much boost, I will set the BOV to soft to have it release early then having it slam all that air in the engine and stalling it.
Like ANY X-PROJECT, you just have to go with the FLOW.. there only enough pre caution you can take. You learn a you go, if it doesn't break then your lucky, if it does break, it's back to the drawn board. Doesn't life sucks sometimes...
Old Apr 9, 2003 | 06:39 AM
Scruit's Avatar
U wanna try me young boy?
Not h8'n, just some constructive criticism...
1) Have you accounted for the movement of the engine under changin loads? If you mount the supercharger to the frame/body in the engine bay then when the engine moves it will affect the way the belt contacts the supercharger pulley. If the movement is front-to-back (most likely on a transverse engine) then you have to make sure there is enough slack AND tension to work effectively the forward/backward extremes of rotation.
2) Have you calculated the effective PSI of new supercharger? Your machinework looks excellent, and I have no doubt that (subject to #1 above) it will produce boost... To calculate that you will need to understand the PSI delivered at a given RPM for the turbo (turbine shaft RPM, not engine RPM) whish is probably something in the order of 10psi at 20,000 rpm. Then calculate the speed that you will turn the new supercharger input pulley, easily calculated as a ratio of the size of the crank pulley to the supercharger pulley. ie if crank pulley is 150mm, and your new pulley is 50mm then that translates to 150/50 = 3:1 (yes, I missed pi, but the result is the same) so in this example at 2000rpm you're spinning the supercharger at 6krpm. At 6krpm you're going at 18krpm turbine speed. I'm pretty sure this is along the right lines - if I'm off base then tell me.
So, if you figure out the psi/rpm of the original turbo, then you should be able to predict boost with some modicum of accuracy. It would be a shame to do all that work and wind up with either 3psi, or 30psi - either would suck.
3) Make you you use a BOV. If you start belching 30psi into your intake you'll find your heads in two different counties.
Old Apr 9, 2003 | 07:02 AM
SR20DEN's Avatar
VQ Wizard
Well here is a flow chart for a standard style T3 compressor wheel. It appears he'll need about 60k RPM to really get anywhere. If it has a 1" impeller pulley and an 8" crank pulley that you can get from vortech the max effective ratio will be 8 to 1. At 8:1 and 6000 RPM the max impeller speed will still only be 48k RPM.
If this thing ever manages to produce 2 or 3psi of boost I would consider it a sucess. But the standard crank pully is too small. Try to get an 8" (or more)crank pulley and use an 8 rib belt.
Keep up the good work.
Old Apr 9, 2003 | 07:05 AM
LeeIt2Me's Avatar
1 - I change the mounting now. Alot of people said it's a NO NO to mount that on the chassis as the engine moves alot when shifting and reving. So it's going to be mounting on the engine, a-la other gen maxima S/C. Will take all the belts out this weekend and take measurements and come up with something.
2 - As for for the boost? I am not a turbo expert. It's a T-3 with a .42 trim on it. The pulley is a 1 3/8 in diameter. if you can do the math for me, I will apperciate.
If this project fails or succeeds, I really don't care. It's a dream of mine to do this. Its a Hobby. Love me or hate me it's going to happen.. HAHHAHA...
Old Apr 9, 2003 | 07:14 AM
abstrakt79's Avatar
i hope it works for you...it seems like you are putting a lot of effort into it and so i hope it pays off...good luck
Old Apr 9, 2003 | 08:21 AM
mzmtg's Avatar
Minister of Silly Walks
How are you going to get that compressor to spin at the 70,000 - 90,000 RPM it needs to make boost?
Old Apr 18, 2003 | 08:01 AM
LeeIt2Me's Avatar
Ok. Update to my project. I redesign the mounting plate. (don't say why is there one bolt holding it, It's just test fitting now. Will add two or more support bracket on later.)
http://www.cardomain.com/member_page...=304102&page=3
Old Apr 18, 2003 | 08:03 AM
Maxman2000's Avatar
A 1990 with SC.
Old Apr 18, 2003 | 08:21 AM
DA-MAX's Avatar
nice work man...you do all this design work yourself? can't wait to see the end product!
Old Apr 18, 2003 | 08:25 AM
Lordrandall's Avatar
Someone has to be the pioneer. Go for it man.
Old Apr 18, 2003 | 11:54 AM
Clayton's Avatar
Yeah...you da man if it works or not.
If us 3rd geners had someone like you that worked for a custommaxima or stillen, we'd have a sc or turbo kit avaialable.
Old Apr 18, 2003 | 12:05 PM
LeeIt2Me's Avatar
Yup, All this is my idea.. did awhole lot of sketching before coming up with this idea. But, like everyone said "HOPE IT WORKS".. if not I would just have one of a kind blower in a 3rd gen maxima..
haha!!
Old Apr 18, 2003 | 12:26 PM
Chinkzilla's Avatar
haha!!
just a thought, but you may have to use a bigger pulley/turbo housing just to make enough boost at the speed that the belt moves...
nice work though
Old Apr 21, 2003 | 07:20 PM
LeeIt2Me's Avatar
Ok, update. Mounted the supercharger and to my surprise it runs.
It puts out decent amount of air (wish I had a air pressure gauge or boost gauge). I think I have to tighten the tensioner it's slipping I think. But beside that, it's WORKING!!. So, next is the PLUMBING, more of a challenge..
http://www.cardomain.com/member_page...=304102&page=4
Old Apr 21, 2003 | 07:22 PM
Sprint's Avatar
Congrats on putting your money where your mouth is. You definately get my respect even if i didn't run, i still give you my respect.
Old Apr 21, 2003 | 07:23 PM
delio's Avatar
Hey Lee, I think your doing a slick job there.
I don't think your getting enough "wrap" on the pulley. I am about 45 minutes from brooklyn if you ever want to reference a 4th gen setup.
Old Apr 21, 2003 | 07:41 PM
LeeIt2Me's Avatar
Thanks Sprint..
Delio:
Well, I made sure I off set the mounting plate where the super charger plate mounts to about 1/4" higher than the other plate(back plate) so the belt rides higher(which takes most of the belt slack)so if I needed more tension I would just tighten the pulley tensioner. Would be great to see an actually max super charger in person, would take you up that offer, Thanks. All my reference is from the internet..
Old Apr 21, 2003 | 07:44 PM
DA-MAX's Avatar
nothing but props from me... you definently are a pioneer, keep us updated!!!
Old Apr 21, 2003 | 08:01 PM
MaDMaX024's Avatar
let me go out on a limb and say this probably will not work for a VE.
what would it take to adapt it to?
Old Apr 21, 2003 | 08:14 PM
SR20DEN's Avatar
VQ Wizard
Major props to you for getting this far.
I really don't want to be negative about your setup but I still notice a few issues that you will need to deal with.
PM, IM or email me if you would like to discuss it.
And keep up the great work!!
Old Apr 22, 2003 | 06:24 AM
delio's Avatar
Thanks Sprint..
Delio:
PM me when you wanna take a looksie.
Old Apr 22, 2003 | 12:17 PM
Keep it up man.
