Wow...a new car that captures the spirit of the 3rd generation Maximas....
Old Apr 9, 2003 | 03:56 PM
  #121
dmontzsta
Epinions.com review.
Pros
Performance, quality, value, comfort, reliability,timeless style
Cons
VTC system, if it breaks, is costly.
The Bottom Line
The '89-'94 Nissan Maxima was well ahead of its time. Many of today's cars still can't top it!
Old Apr 9, 2003 | 05:03 PM
  #122
MAX2000JP's Avatar
The only car that is made by Nissan that can truely carry the 4DSC sticker is the G35. Nissan should have converted the 6th gen to RWD and made it sportier, but that market is already filled by the G35. The current Altima filled the "spot" of the Maxima and the 6th gen went upmarket to take on the Avalon
As for the 3rd vs 4th vs 5th gens, I think they all have their good and bad points. The VQ is clearly a superior engine, but the 3rd gen does have IRS. I would rather have the engine instead of a IRS because you really don't notice any drawbacks of the beam. Nissan's beam is a pretty decent design, for what it is. From a performance standpoint, the 4th and 5th Gens have a advantage over the 3rd gens. A lot of this arguement is subjective.......
Old Apr 9, 2003 | 05:10 PM
  #123
dmontzsta
That makes no sense. The VE engine is just as powerful as the VQ, then what? you have a good engine and IRS. No drawbacks with the beam? try getting into a down and dirty bumpy twisty high speed turn, then you will see the drawbacks...
Old Apr 9, 2003 | 05:16 PM
  #124
MAX2000JP's Avatar
Makes perfect sense, the VQ is a better engine and my buddy Ward's says the same thing. As for IRS, its not as great as people make it out to be. The beam axle on the 4th and 5th gen puts up good numbers in the slalom. I could care less about how it handles on the streets because I don't push my car on subpar roads.
Old Apr 9, 2003 | 05:22 PM
  #125
dmontzsta
When the VE came out, it was raved about also... ...VQ has just been out longer.
So slalom is everything eh? Geez, we all know there are lots of 4th gen guys that trailer their cars to the slalom coarse for the still competition
Old Apr 9, 2003 | 05:26 PM
  #126
nummaonenutsaq's Avatar
Yeah, I only push my car when I'm out running laps on the Long Beach Raceway. It's ludicrous to push it when you're on the actual STREET. Anyone that would do that .. would be in the majority.
Old Apr 9, 2003 | 05:28 PM
  #127
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Ah, here we go with the denials that the VQ engine is more powerful right on queue.
So which engine has more area under the curve?
Where did all the low/mid-range in the VE go?
Which engine is 100lb lighter due to aluminum?
Old Apr 9, 2003 | 05:36 PM
  #128
MAX2000JP's Avatar
Take a look at Steves graph and correct me if I am wrong, but I didnt see a VE on the list. The VQ has won the best engine award for numerous years because frankly, its that good.
As for slalom, this measures how well a suspension works in transitions. This is the true measure of handling, besides actually testing at a road course. IMO if the beam was so inferior, it would show up in testing.
Old Apr 9, 2003 | 06:04 PM
  #129
Jeff92se's Avatar
I'm needing a caw
Donald, you gotta learn how to present your case better.
No one said the VQ wasn't more powerfull. It's one damned nice engine hands down. The VE is good too.
But saying the irs doesn't make that much difference while bashing the VE engine at the same time makes no sense. Why? Because IRS will benefit the user all the time. Not just at the track. Almost any bumpy curve regardless of speed will show the shortcomings of the beam axle. I could just as well say, the differences in engines don't matter because you shouldn't street race and that the only time the differences show up is at the track. The VE and VQ are pretty close in performance. So close that I say what the VE lacks in the low end is made up in the high end.
Put is this way, you can tweak the VE's engine to go as fast as a VQ. But I challenge someone to tweak a 4-gen beam suspension to be able to handle less than perfect curves(ie.. real life) as well as the 3-gen IRS. You probably can't due to the limitations of the simple design.
Also you can't tweak the 4-gen's build quality or paint w/o MAJOR expense. That's another benefit that's noticable every day/all day/7 days a week.
edit: results of a salom on a smooth surface is not the same test on a bumpy surface. On a smooth surface, even a car w/ absolutely no suspension at all will work well.
Both are nice cars.
Old Apr 9, 2003 | 06:26 PM
  #130
MAX2000JP's Avatar
Both are nice cars.
In my 3 years of owning a 5th gen, I have never experienced any of these so called short comings of the beam suspension. I can handle the roads around Chicago just fine. My car is no Z06, but it handles well for what it is. Any car, be it IRS, beam, or live axle will be upset if you hit a mid corner bump. I personally do not see that much advantage of a IRS besides ride in our application. Again, if the design was inferior it would show up in testing. The main problem with the Maxima's handling is FWD and its weight bias. 3rd, 4th, and 5th gens all share this common trait. I think that people tend to think that the beam is a poor design, but it works well in this application. Kinda like pushrods, thats old technology, but the LS1 is a very powerful engine using technology that dates back to the 50's
Old Apr 9, 2003 | 07:18 PM
  #131
todamax's Avatar
Re: Re: Re: Re: my thoughts.
Originally posted by MaximaGXE93
Not if you want my car 93k
Or mine. 62.5K
And I did go looking for a Max with low miles. I found it in FL, and got it for a steal.
Old Apr 9, 2003 | 08:13 PM
  #132
Anuj's Avatar
wow took me a good 30-40 minutes to read this thread. I love it actually. I know so much more about the 3rd and 4th gens now.
Have you noticed no one really bashed the 5th gen....yet
My personal opinion is that the 02/03 Maxima looks the best, not the 97-99
Old Apr 9, 2003 | 08:51 PM
  #133
dmontzsta
Once again, slalom isnt the "real world". If ANY 4th or 5th gen owner thinks the beam is better, you are just trying to make it seem better, cause that is what you are stuck with. You are pretty delusional to think that. Slalom is FLAT, and it also has alot to do with tires/rim size, the 3rd gen comes stock with 15" rims and crummy tires and most of the new Maximas have 16s and 17s, this helps. Correct me if I am wrong, but I think both 3rd and 4th gen had very similar test times, but take it to the street, and it is a different story.
Jeff, you have a very good point here...
"you can tweak the VE's engine to go as fast as a VQ. But I challenge someone to tweak a 4-gen beam suspension to be able to handle less than perfect curves(ie.. real life) as well as the 3-gen IRS. You probably can't due to the limitations of the simple design."
If you look at Steves graph, you will notice, there isnt too much difference, the VQ has the low end advantage, but the VE has the high end, the race would come down to driver. If you are in the VQ (no-lsd ) and you dont know how to launch, you might as well give it up.
Dont get me wrong, ALOT of people here try and judge me, I do not hate ANY Maxima, people that really know me, know this. In fact, I have talked 2 people into getting Maximas, 4th gens BTW.
Old Apr 9, 2003 | 09:32 PM
  #134
Dave B's Avatar
Not DAVEB the parts guy
3rd geners can ramble on about the IRS, but over most surfaces and handling situations, the beam does just fine. Only when you encounter VERY bumpy turns does the beam axle become unsettled. Nearly all the 3rd geners DO NOT own 4th gens so how do you really know the real characteristics of the beam? I swear most of the 3rd geners are clueless about the true setup of the beam in the 4th/5th gen. It's not lowtech by any means. I'd rather have an IRS, but in most driving situations, the beam does just fine.
As for the VE vs 3.0 VQ. You guys don't stand a chance when it comes to NA modifications, so don't go there. I remember only one VE 3rd gen that pulled off lower 14s@97mph. All the other NA 3rd gens are left way back in the upper 14s and 15s. 3.0 VQs on the otherhand are quite capable of lower 14s@100mph on street tires and mid 13s@101 on slicks. Where are the VEs? Even without the MEVI/JWT ECU, the VQs are quicker and faster on average.
Dave
Old Apr 9, 2003 | 09:50 PM
  #135
Maximan190's Avatar
Hm..there must be some kind of difference.. when i drive my moms 03 SE i feel like im gonna take off and fly away, the suspension feels so soft i feel like the car is floating. In my 3rd gen i actually feel the road, and when im doing 100 i know im doing 100 and not like 50. The 03 feels too "light" vs the 3rd gen which feels like it makes a connection with the road, hell im even on stock suspension still. For comfort, then beam is the way to go... for driving/performance gimme IRS
Old Apr 9, 2003 | 10:08 PM
  #136
NYCe MaXiMa's Avatar
2 comments, about the 2 arguments being presented here:
IRS
One of the very 1st things I noticed when I went from the VE -> VQ was the handling. I "felt" the car more in my 93 on turns.. It just seemed to hold the road better, however, I did have some sticky 225/50/16 Sumitomo HTR+s on some lightweight 16s.. and tires really do make that much of a difference. But, my front struts were shot on the 93. The steering was tighter on the 93. on turns, going over bumps, especially on these great NYC roads, I did feel like i had more control of the car. My 98s rear end would kick out sideways a bit more, and the lighter steering of the GXE made it feel weird too... However, on a nice smooth road, it felt great. I was able to push my VE harder around sweeping turns because of the better tires..
Al in all, I noticed the VE acted better in turns over a messed up road. But I, and hopefully no one else with some sense ever tried to take turns with uneven pavement aggressively because IRS or not, it is dangerous. So the trade off wasn't so bad.
Another problem. The back feels way too stiff. going over bumps, evne on straight roads.. it just comes down hard, feels like there is zero suspension travel..
2. VQ vs. VE technology..
I'm guessing the VE paved the way for the VQ. It's glitches were worked out and the VQ came out. The VE is also a noisy engine, it's not as smooth, it has some issues, be it the VTCs or whatever else. The VQ seems to be far more quiet, way more smooth.. and problem free. Not to say one will outlast the other. They just behave differently.. These are just things i drew from my personal experience and comments i've read from others.
These little things really make a world of a difference in the way the engine feels. The VQ feels so strong at all times.. The VE just felt weaker to me..
I don't know who to blame for the suspension. Nissan, or the roads of New York City Because when I visit other places with smooth roads, I don't mind my beam one bit.
Engine wise, I like the feel of the VQ. It's so smooth and quiet
Old Apr 9, 2003 | 10:26 PM
  #137
dmontzsta
Dave
Dave, Dave, Dave. Once again, the reason you dont see all the VE numbers, is cause the 4th gens outnumber the VE by about 85%. The VE members here that mod their cars, I can count on both hands. The 4th genners, I would need a calculator and alot of time.
Old Apr 9, 2003 | 10:32 PM
  #138
Dave B's Avatar
Really shouldn't matter if it's so easy to make as much power with the VE.
Dave
Old Apr 9, 2003 | 10:34 PM
  #139
dmontzsta
Dave
Are you doubting the VEs power?
It seems alot of 4th genners think the VE is lacking the power of the VQ, by a landslide, it is still right there, and isnt going anywhere
Old Apr 9, 2003 | 10:48 PM
  #140
Matt93SE's Avatar
STFU n00b!
SHUT THE HELL UP!
Lakersallday24
Jun 16, 2019 01:35 AM
Greenmaxspeed
Aug 31, 2015 09:06 PM
Greenmaxspeed
Aug 8, 2015 12:39 PM
laparka66
Aug 6, 2015 09:36 AM
ViciousVQ30
Aug 5, 2015 05:40 PM
