Wheel alignment and negative camber
Old Apr 9, 2003 | 12:12 PM
JoesMAX's Avatar
I installed my AGX's last week, and the front eibach's are cut one coil giving it a nice drop, about 1.5 finger gap in the front and 2 in the back.. I took the car to goodyear for an alignment, because im still under warranty from when i had it aligned in august.
now my question is, how bad is it if my camber is -2 degrees? the guy didnt want to cover it under warranty and said my struts looked new, but i just told him thats how my car was the last time i was in there, and he finally agreed to cover it this time. hes going to adjust the toe, but the negative camber will still be there, and i wanted to know if its really going to put excess wear on my tires, being that -1.5 is within spec. i am going back in a little while for them to do the alignment because they were busy... also will my alignment get thrown off easy with my setup? i dont feel like spending a few hundred for camber plates, and then having to have it aligned again.. thanks in advance
Old Apr 9, 2003 | 12:18 PM
Jeff92se's Avatar
I'm needing a caw
Ah, you shouldn't have cut the coils. Neg 2 deg camber is gonna eat your tires alive. Get some camber bolts quick(I mean order them today and have then installed/aligned within 1 month)
Old Apr 9, 2003 | 12:28 PM
JoesMAX's Avatar
how bad will it wear my tires? are we talking like 50% faster? i didnt cut the springs, i got them cut and i still have my uncut springs but i despise the saggy rear look.. how bad is the camber with sprint springs? my front isnt any lower than sprint fronts would be, its actually a little bit higher in the front than 4th gens ive seen with sprints..
if its that bad, ill look into getting camber bolts and then having it aligned, but i have nothing to lose rigth now since this alignment will be covered under warranty.. thanks for the help
Old Apr 9, 2003 | 12:37 PM
Jeff92se's Avatar
I'm needing a caw
If you got maybe 35,000 on a set of tires, you will probably get less than 1/2 w/ that crappy camber. The inner tread will be bald while the outer will be brand new.
You did read the the suspension sticky RIGHT?
Old Apr 9, 2003 | 01:02 PM
araffio's Avatar
Joe, buy some Eibach Camber Bolts from Alex at SouthWest and you'll be fine, they'll get your camber aligned perfect. Only $30...
You know how low I am and my alignment is perfect. My guy said the camber bolts were an excellent purchase
Old Apr 9, 2003 | 01:27 PM
96BLUMAX's Avatar
Or just get your car aligned cause mine didnt need the bolts at the place i took it to.
Old Apr 9, 2003 | 01:30 PM
Jeff92se's Avatar
I'm needing a caw
You can get it aligned a billion times, the camber will still be neg 2 degrees until he gets some camber correcting hardware in.
Old Apr 9, 2003 | 01:32 PM
JoesMAX's Avatar
for some reason on the printout from the alignment it shows left front camber -.5 and right front camber -1... i dont know if he was just guessing -2 degrees before, or he just threw those #'s into the computer.. either way ill just pick up some camber bolts and throw them in in a few weeks, at least my tow is fine for now, and these front tires are on their way out anyway so if i wear them down its not the end of the world.. thanks for your help Jeff, and sorry i didnt read the sticky
Old Apr 9, 2003 | 01:36 PM
Jeff92se's Avatar
I'm needing a caw
Neg .1 and .5 is well within specifications. If those are truely the correct specs then you don't even need the bolts technically.
Old Apr 9, 2003 | 02:23 PM
JoesMAX's Avatar
yea but im not sure if those are the right #'s because it shows before and actual as the same #'s, while he told me earlier it was off -2, unless he was just estimating the -2... would -.1 and -.5 show? because you can see that the wheel has a little negative camber, but its not like the back wheels of a civic or anything
Old Apr 9, 2003 | 02:26 PM
costcowholesale's Avatar
since you started an alignment thread I'm gonna throw my stuff in too
did my alignment yesterday with AGX/H&R (3.5 finger gap in the front )
my toe out before alignment was 2.8 and 3.2
now its at 0.1 toe in and steering feels a lot beter, also my negative camber is like -0.7... is that ok?
Old Apr 9, 2003 | 02:28 PM
Jeff92se's Avatar
I'm needing a caw
-0.7 should be okay.
Joe: If the readings from before/after are exactly the same, something is fishy. Neg 2 deg camber will definately be noticable. Cheap civic lowering noticable. Anything under 1 deg neg and you might not even notice unless you know what to look for.
Old Apr 9, 2003 | 02:38 PM
JoesMAX's Avatar
yea im thinking maybe the guy just entered a # into the computer or something... im going to take pics right now of my front wheels, see if that might help
Old Apr 9, 2003 | 02:55 PM
JoesMAX's Avatar
pic 1
pic 2
the way the fenders come out and then back in make it harded to tell, because the fenders arent exactly 90 degrees with the ground either, but let me know what you think from these pictures
Old Apr 9, 2003 | 03:04 PM
Jeff92se's Avatar
I'm needing a caw
Hard to tell but that doesn't look like 2 deg neg. I "think" you're okay. But maybe have the shop put it up the rack to confirm? I mean there's no way it could be the same before/after. So I think you're entitled to some accurate specs.
Old Apr 9, 2003 | 03:08 PM
JoesMAX's Avatar
i was going to call goodyear to ask them, but the guy seemed pretty ****ed that he was doing it under warranty, since he knew something was up.. maybe ill give it a few weeks and see how my tires are, since these tires will need to be replaced in a few months anyway. if anything ill try to put in the camber bolts and get it aligned when i get 2 new tires for the front, so i know everything is good.. thanks again for the help
Old Apr 9, 2003 | 03:30 PM
Maximan190's Avatar
pic 1
pic 2
yea i can kinda see that it doesnt look 90° with the ground, but yet your right it is hard to tell
get the camber corrected..
and maybe some wheels spacers too, just a imo suggestion, i think it would enhance the stance some more
when i swapped back on my 99s a few weeks ago, the tires on my stock set were worn badly on the inside on all 4 tires but they didnt even look misaligned or anything when they were on the car; probably from when i spun out on a wet highway last summer and hopped over the median sideways... im not getting an alignment done until my new tires and suspension is in which should be next month
Old Apr 9, 2003 | 05:33 PM
maximus75's Avatar
The #'s are the same beacause the camber wasn't adjusted. It's non adjustable until you get the adjustment hardware.
Old Apr 9, 2003 | 06:12 PM
JoesMAX's Avatar
im not sure if the #'s are even correct though... if those are the correct numbers, i should be fine the way it is.. even if they cant adjust the camber, doesnt it change slightly from doing the alignment? when i looked at the alignment done in august the before and actual #'s are slightly different.
Old Apr 9, 2003 | 06:16 PM
ZeRo MaX's Avatar
I'm wondering how long do u need to wait for an alignment after you get dropped.. also how can you tell the wear of the tire? (from being lowered)
Just to add on to the post...
Old Apr 10, 2003 | 07:50 AM
breaux124's Avatar
Ingalls camber bolts for $23 shipped
http://www.lightningmotorsports.com/ingalls.htm
My camber was -1.5 and -1.6 and the inside of my tires wore real quick. With the camber bolts I've gotten it to -0.2 on both side, my car tracks better (no more pull) and my tires don't wear as fast now.
matts95max
Apr 23, 2025 10:44 AM
Fbana41
Aug 29, 2016 12:18 PM
coolsun
Wheels/Tires
Oct 15, 2015 10:52 PM
Andy29
Sep 29, 2015 05:32 AM
dcam0326
Sep 8, 2015 11:02 PM
