Suspension 101 question...
Old Apr 15, 2003 | 08:15 PM
Punch84's Avatar
I am totally new to suspension upgrades and would appreciate some insight. What's the difference between lowering springs and coilovers? Pros and cons of each? Will using lowering springs on stock shocks and struts cause problems down the road? I'm totally in the dark. Thanks.
Dave.
Old Apr 15, 2003 | 08:33 PM
ch13f's Avatar
Coilovers are basically lowering springs, however you can adjust the ride height of them from anyhere to 1" to 4" lower than stock. They will provide for the best handling but usually will make noise. Lowering springs are, depending on what brand, cheaper and are not adjustable. Usually they range from a 1" to a 2" drop. If you use lowering springs on the stock struts/shocks, they will most likely blow after some time, and handling won't improve much, might even get worse.
Apr 16, 2020 05:15 AM
knight_yyz
Nov 1, 2015 01:34 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
