My Clutch Pedal Sticks to the Floor
Old Apr 18, 2003 | 01:25 PM
96jerzeymax's Avatar
My 96 Se has been parked the past few days awaiting my Exedy Clutch and I went out to it today and just barely touched the clutch pedal and it sprung to the floor and stuck there. It doesn't disengage the clutch at all. I can bring the pedal back up with my hand. Any idea whats going on?
Old Apr 18, 2003 | 01:48 PM
syc's Avatar
syc
Re: My Clutch Pedal Sticks to the Floor
Did you do something and not installing it right|? if not, maybe
the master cylinder, slave cylinder, or the oil line is bad. but probably the slave cylinder.
Old Apr 18, 2003 | 01:50 PM
Victim64's Avatar
Re: Re: My Clutch Pedal Sticks to the Floor
Maybe I read it wrong, but I thought he hadn't installed it yet?
Old Apr 18, 2003 | 02:42 PM
Charcoal95GXE's Avatar
My friend just had the same EXACT problem in his car...they replaced the slave cylinder and all this other stuff, and it still did it ,but then they replaced the pressure plate, and that was what was wrong.
-Brian
Old Apr 18, 2003 | 03:25 PM
2K2DEMAX's Avatar
Pele ain't got nothing on me
Good call. This is a hydraulic problem. I had this fixed yesterday at the dealer and mine was the clutch hose, it was leaking. The tech told me exactly what syc said. In my case, the clutch was fine (it's less than a year old) it's just that the hose was leaking and all the fluid was almost gone causing the problems.
Old Apr 18, 2003 | 05:25 PM
sleeper's Avatar
yup
pressure plate
Old Apr 18, 2003 | 06:49 PM
Ramius83
Check to see if there are any leaks underneath the car, on the slave cylinder, or the master cylinder. Your problem is hydraulic line/part related...
Old Apr 18, 2003 | 10:40 PM
Maxman2000's Avatar
Return Spring that pulls the paedal back could be doin it.
Old Apr 18, 2003 | 11:50 PM
NYCe MaXiMa's Avatar
how about if the clutch pedal is too stiff to depress?
what can cause that?
mine has been gradually getting stiffer with time.. it's quite worn, I'd suppose but it grabs like a champ, often too hard..
i'm bleeding the clutch fluid tomorrow.. already changed the MTF.. not sure where to look, it's gotten to a point it's hard to drive the car.
Old Apr 19, 2003 | 01:24 AM
meccanoble's Avatar
Sports Button FTW
that happened to me after i went through conversion. There's a silver **** that holds the clutch wit some part of the car so when pressed down it comes back up. Maybe that piece fell off. If it did, u can take a paper clip and put it through the hole and it will bring the clutch up when stepped on...if it wasnt so late i would take a pic and show u, its kind of hard to see but if u feel the clutch pedal arm all the way up, u can tell if its missing by feelling a hole somewhere....
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
