whats the best/easiest/fastest way to bleed the clutch master system?
Old Apr 18, 2003 | 07:43 PM
Soon2BMaxed's Avatar
i just put in a new slave and master cylinder in the maxima and after quite a bit of bleeding i dont seem to be building up much pressure.
a friend of mine said that when you do both at the same time you're supposed to bleed the master then the slave and repeat that over and over and over. he said a nissan techie told him this. they also said that the whole process takes over an hour and you're supposed to keep bleeding even if nothing but fluid is coming out.
i just wanted anyone with experience to comment......
Trevor
Old Apr 19, 2003 | 12:42 AM
xHypex's Avatar
I had to replace one of the hoses running between the slave and master cylinder, so I got to bleed from a dry system. I started with the upper bleeder on the strut tower since most of the air will rise there. I then bled the lower bleeder near the slave cylinder, and bled the upper bleeder one more time. There's not a ton of fluid in our hydraulic system, so it shouldn't take too long or too much fluid.
-hype
Old Apr 19, 2003 | 02:27 AM
nismo2020's Avatar
Needs non-Maxima Friends
i did it by the FSM and it took only about ten minutes. IIRC.
Old Apr 19, 2003 | 02:04 PM
wtf? then there has to be something wrong. we bled almost a full bottle of fluid through already.
i dont know wtf else this could be
Old Apr 20, 2003 | 03:02 PM
nismo2020's Avatar
well i didnt replace all the parts, i was just bleeding the system.
Old Apr 20, 2003 | 04:35 PM
matt calder's Avatar
Its going to take you a little while.
Old Apr 20, 2003 | 05:53 PM
Cutler's Avatar
Take it to the dealer
Old Apr 20, 2003 | 10:47 PM
not a f---ing chance.
user 11122324
42
Jul 18, 2022 03:35 PM
knight_yyz
Nov 1, 2015 01:34 PM
MichMaxFan
Sep 30, 2015 09:18 AM
