Help! Tranny Problems?
Old Apr 20, 2003 | 11:04 AM
98maxsel's Avatar
Hey,
My tranny feels like its about to fall apart. I only have 45k miles on my car and it's a 98 5 speed. It all started after I got home from the dragway. I did massive wheel hops everytime I took off and now I have trouble putting the car into gear while driving. Sometimes its fine and sometimes it just locks up! I know its not the clutch cause I just got an ACT couple months ago. Going into third sometimes makes a grinding noise. What could be possible probs? any help please! thanks
-tim
Old Apr 20, 2003 | 12:58 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
SSS
Old Apr 20, 2003 | 06:06 PM
98maxsel's Avatar
anyone??? whhats SSS?
Old Apr 20, 2003 | 06:22 PM
njmaxseltd's Avatar
Re: Help! Tranny Problems?
The Maxima is a 4 door family sedan with a powerfull engine. It's not a drag car and never will be. Stop the wheel hop and your tranny will last a very long time.
You probably tore up the internals of your 5 speed pretty good. Not to mention the beating your drive shafts & control arms took as well. Try different tires to stop the wheel hop, lower tire pressure, stiffer engine mounts, control arm bushings, springs and struts, ect..
Next time your car does wheel hops at the track, go home and try to figure out how to stop it from happening. Don't keep dragging it like that, it gets expensive!
Old Apr 20, 2003 | 09:14 PM
ericdwong's Avatar
I really hate the 4th gen tranny...anyway you probbly broke something. When you proceed to your next step ask me and I can probbly help you out.
Old Apr 20, 2003 | 09:25 PM
98maxsel's Avatar
thanks guys...
I defin. think something is not right here... I still have warranty. Is this something I can prolly get swinged under warranty??? What kind of stuff can break from hard driving? wheel hop dragging?
Old Apr 21, 2003 | 04:02 PM
98maxsel's Avatar
help!
Old Apr 21, 2003 | 06:44 PM
Dave B's Avatar
Not DAVEB the parts guy
The wheelhop is typically induced by releasing the clutch too quickly. The drivetrain shock causes the tires to hop because the motor is rocking in the mounts. Next time you get hop, let off the gas ASAP.
As for your tranny, so many things can happen under prolonged hop. From what you're describing, it sounds like you might have broken some teeth off the gears. Your shift fork may be slightly bent too.
Dave
pktaske
May 6, 2016 07:49 AM
Socalstillen
Sep 20, 2015 11:46 PM
iamute
Sep 20, 2015 05:22 PM
pktaske
Sep 4, 2015 08:40 AM
Lowered_a33
Sep 1, 2015 07:49 PM
