help! question about maxspeed sag
hey i need some advise, ive got a 4th gen and ive been loving the drop of the maxspeed springs. but recently kinda out of nowhere its started to sag on the left rear and front right sides (by about an inch). I am woried because i dont want to hurt anything, and plus its visually quite noticable.
please help, has anyone had a problem like this? i dint think maxspeeds had this problem thats why i am asking. could it be the springs or maybe the struts? what should i do?
BIG THANKS.
BIG THANKS.
Did you install them yourself? Possibly put one in upside down? Make sure the coils with gaps between them are on the top, and the coils pressed together are on the bottom. Possibly in the rear the spring could have fallen off the strut mount.
And how can the front right and rear left sag at the same time? wouldn't that push the whole car down? Maybe u parked on uneven pavement?
i had one of the experienced members of the org install them, but it is sagging on even pavment, its very odd to me also the front and rear oppoisite sides are sagging. more help would be great.
Re: help! question about maxspeed sag
BIG THANKS.
BIG THANKS.
Your car would have to be bent in order for that to happen.
Maxspeeds should be installed with the writing on the spring so you can read it. That means the coils closer together are on top.
yeah the writing reads right side up, and the coils are tighter together at the top. but lets say when you look rears the left side has 4 coils that are evenly spaced before they become pressed together, where as the left side there are only 3. so somewhere it is off, and i dont know why?
exactly, but for me every wheel has a different height. i mean like the left rear wheelwell is about an inch over tire, the front left is about 6 inches, the right front is lower than the left and then the rear right is higher than the left rear. its feels akward, and looks like pure s**t!
anyone else w/ advise?
This is the correct way
ohh, and the pressed together coils are on the top not the other way around, are you sure their spose to be on the bottom.
I believe yours is the first one to sag.
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
I've never heard of maxspeeds having sag problems. I've had mine for like 9 months now, no sag, no problems. What kinds of struts do you have? Maybe a strut bearing or something?....
