tranny prob: what causes excessive play in shifter
Old May 2, 2003 | 09:20 PM
nadir_s's Avatar
vicodin ... gift of life
well i've had my differential bearings gone bad for a LONG time. I have sooooooooo much play (shifter rod) when i'm in gear. what would have to be damaged in order for that to occur? It feels like i'm in neutral when i move it around. I'm just curious, thanks.
Old May 2, 2003 | 11:20 PM
Nismo's Avatar
maybe the detent ***** and springs are worn or loose?
Old May 3, 2003 | 12:25 AM
meccanoble's Avatar
Sports Button FTW
my friends corolla is exactly like that, i hate that. I have a tiny play but nothing to go crazy about. I heard it was the return spring. I bought one new on my first max and there was no leeway or movement in gears, barely any in neutral...
Old May 3, 2003 | 02:36 AM
hlh0501's Avatar
there are two black rods that connect the shifter to the tranny. one shifts the gears in the tranny, the other is stabilizer to make it feel/work right. could it be possible the bolts backed loose on the tranny end of the stabilizer bar? i know if the stabilizer is loose it can get verry nasty (from experience) ..
Old May 3, 2003 | 03:01 AM
joaquink's Avatar
¿Hablas Español?
Old May 3, 2003 | 10:05 AM
nadir_s's Avatar
thanks guys
Old Jun 12, 2003 | 05:39 PM
nadir_s's Avatar
hi guys....
it's been 1 month since I made this thread, but thought i should just bring it up.
My tranny is under rebuild right now and I had a quick question. About this shifter play... is this something inside the tranny itself or is it something outside (connected to shifter somewhere)??
I'm talkin about the detent ***** and springs. Thanks!
Old Jun 12, 2003 | 10:11 PM
Nismo's Avatar
the ***** are inside the tranny and they are pressed up against the rods using spring force. the rod itself has a notch in it whrere they rest in. theres also 1 spring(return spring) thats located directly under the shifter stick thats conected to both shift rods and if that spring is worn out then it will wobble around when the stick is in neutral.
Old Jun 12, 2003 | 10:49 PM
nadir_s's Avatar
thank u!
gotta talk like i know something to the tranny ppl now lol
Old Jun 12, 2003 | 11:18 PM
meccanoble's Avatar
Sports Button FTW
lol, i know the rods are outside the tranny, the spring i thought was outside tranny too. and the ball holding the shifter is inside the tranny but its not part of tranny. Not sure if u were looking for parts of the tranny or parts seen inside teh tranny...
Old Jun 13, 2003 | 12:11 AM
Nismo's Avatar
well the control rod shift linkage is outside of the tranny which is probably what your talking about but its the actual rods that move the forks is whats inside along with the detent *****. you can remove the detent ***** from outside the tranny tho. http://www.motorvate.ca/welcome.htm has pix of what they look like and all
Fbana41
Aug 29, 2016 12:18 PM
fx4five
Oct 18, 2015 06:57 PM
fx4five
Oct 1, 2015 04:58 AM
uttadms31
Sep 30, 2015 05:24 AM
atriuum
Sep 28, 2015 01:19 PM
