Just ordered 300ZX brake calipers
Old May 7, 2003 | 12:39 PM
Nealoc187's Avatar
SLOW
I just purchased a set of 30mm aluminum loaded calipers for $100 each. Calipers are reman calipers, new seals and gaskets and even come with some cheapo pads to use on the street. I'll be getting some crazy pads for use at the track, Hawk Blues or something in that vein.
I also just ordered new strut mount bearings, a set of Speed Bleeders, and a set of Eibach camber bolts.
I'm looking for the best deal right now on 300Z rotors and will be ordering SS lines shortly.
Since no one's replying to my other thread, does anyone know the diameter of the stock 4th gen rotor?
Old May 7, 2003 | 12:59 PM
Matt93SE's Avatar
STFU n00b!
STAY AWAY FROM HAWK BLUE/BLACK PADS!!
you'll be replacing the rotors before the pads wear out.
Pick up some porterfield, Carbotech, or EBC pads.
possibly contact wilwood and see if they have something in your fittment. if they do, get the C compound for track days, and the T compound for street.
OE rotor is 10.8 x 0.86" I believe.
while you're at it, pick up a set of skyline rotors and build some new mounting brackets out of aluminum or steel. you'll thank me afterwards.
http://www.ee.utulsa.edu/~mblehm/pics/car/brakes/ (my projects)
http://www.ee.utulsa.edu/~mblehm/pic...es/rotors2.jpg (OE 3rd/4th gen rotors vs. R32 Skyline rotors)
Old May 7, 2003 | 01:10 PM
Nealoc187's Avatar
SLOW
I'm not concerned with rotor wear but I'll look into other options.
As for the rotors I have to be able to fit them under 15" wheels (still gotta be able to bolt the drag slicks up) so the skyline rotors are out of the question. Bummer huh?
Old May 7, 2003 | 01:15 PM
Nealoc187's Avatar
SLOW
Matt do you have an AIM name I have a few questions since you seem to have done this before.
Old May 7, 2003 | 01:19 PM
Matt93SE's Avatar
STFU n00b!
I use ICQ mostly. number there is 23251481
I'm in the middle of finals right now though- just took a break from studying to check the board.. last day is tomorrow though!!
Old May 7, 2003 | 01:29 PM
Nealoc187's Avatar
SLOW
I'll just ask here, then I don't have ICQ anymore.
I get the impression from reading the posts returned through search that stock brake lines will work but 300Z lines will work "better" because they use a flare fitting rather than a banjo or something. I'm ordering SS lines here very soon will maxima SS lines work? I'm getting front and rears so the rears will still have to be maxima lines unless 300ZX rear lines work in the rear of the maxima.
Old May 7, 2003 | 04:31 PM
paulsfds's Avatar
Hey, I'm just wondering where you bought these calipers from because I was also interested in getting some? thanks
Old May 7, 2003 | 04:39 PM
krismax's Avatar
Father of the 00 VI
Re: Just ordered 300ZX brake calipers
in a 97 car mag there listing 11.0 front 10.9 rear. Neal whereb did you order all of this stuff and do you have part #s. I wonder if down the road if you could get aluminum hat rotors. with alum hats ,drilled , slotted and alum calipers i estimate weight savings at about 60 lbs.
Old May 7, 2003 | 04:56 PM
Nealoc187's Avatar
SLOW
Re: Re: Just ordered 300ZX brake calipers
That's weird, because after milling the 300zx rotors the diameter will be 10.71". ((280mm-8mm)/304.8mm) x 12" = 10.709"
Anyhow the shop that I sometimes go to to borrow the air tools and work on my car got them for me from a wholesaler who only sells to businesses.
As far as weight reduction that's why I went with the 90-92.5 Aluminum 30mm calipers rather than the 93-96 cast iron calipers. All that weight is unsprung too which is even better than just taking off sprung weight
BkGreen97
Apr 2, 2016 05:47 AM
220k+ A32
25
Oct 3, 2015 09:09 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
