Reverse Indiglo Gauges install?
Old May 13, 2003 | 05:21 AM
Pizatt's Avatar
Does anyone have any Install instructions for Reverse Indiglo Gauges. The instructions that came with them sucked!!!!!!!!! They are all blurry as if they were copied, from a copy that was copied from a copy... Anyways, if anyone wants to lend a hand or provided me with some instructions, I would appreciate it.
Old May 15, 2003 | 08:17 AM
PiotrC70's Avatar
Where are you stuck??? they're pretty simple and most likely the same on all cars. Put the sticky stuff on the back of the indiglo guage (some toward the middle as well so it doesn't bubble up and touch the needle) slip it over the needle carefully, (sometimes getting it around the thicker portion of the needle is tough) and lay it down where you want it. Do each guage seperately and run the wires out to the releay. I know the instructions should show to wire the relay to the back of the guage cluster directly but you can hook it up to the dimmer switch.
Good luck. (yes I do have indiglo guages but the 7 color ones)
dcam0326
Sep 18, 2015 04:52 PM
97_GXE
20
Sep 17, 2015 08:12 PM
NissanNismoZ
Sep 12, 2015 07:30 AM
minsbang
Sep 11, 2015 08:48 PM
asianstyle
Sep 10, 2015 11:30 AM
