Cattman/stillen/warpspeed Y-pipes
I have a 2000 Maxima SE automatic California emissions model. I want to purchase a y-pipe ASAP, but I am confused as to which one to buy.
I have heard various fittament problems with Warpspeed along with unequal pipe lenghths not giving it as much power as the other brands, bees in the can complaints with cetain brands, flex sections on the Cattman needing to be repaired, y-pipes banging under hard acceleration, problems with mounting brackets needing washers to allow more room or being completely removed, poor quality with Stillen and list goes on and on...
Can someone please help me with which y-pipe will yeild the most power, fit the car correctly and have excellent workmanship.
YOUR HELP IS GREATLY APPRECIATED,
CTK
CTK
All the y-pipes will essentially yield all the same power. It's a matter of will it rust, or will the flex section break down. Cattman used to have problems with their flex sections but they since fixed that with the new model pipe. Also their pipes are stainless steel and will not rust. More suited for winter areas that use salt on the roads. Still on the other is a good quality pipe. Even though their ss they will still rust. I suggest you spray a coat of high temp black paint on it before putting it on. Still and Cattman are the more expensive of the pipes. Warpspeed and Budget are the cheaper in the $180 range.. Cattman and Still are $330+ range
Re: Cattman/stillen/warpspeed Y-pipes
So if I bought the Budget (I don't think I'll get a warp speed just check out all the ****ed off people on this forum) I can get some high temp black spray paint and it will work just as good as the Cattman? I am tight on dough, but I still want too get decent parts.
lrb6805
09-17-2015 04:49 PM
Violator
09-09-2015 10:14 AM
