Wheels seems to shake and cars pulls to left...please look
Old May 13, 2003 | 10:59 PM
madmax97's Avatar
Well im not sure if this started before or after my trip but anyway. I hit some mean "potholes" a few weeks ago and now my cars seems as if the wheel shakes, it may have before but after i hit those potholes i think it even more. Anyway my question is do you think i need realignment or did i break anything. I have 235/25/19 on sprints so i know the ride is gonna be crappy and with small tires you feel alot, but its just worse of a though now after hitting the holes. Does anyone else have this problem. Also when i let go of wheel it seems like 80% the time the cars pulls left, is this just the road ? of what. Thanks sorry if anything is messy or run-on its late and im angry.
Old May 13, 2003 | 11:10 PM
drewm's Avatar
Re: Wheels seems to shake and cars pulls to left...please look
If you rims are 19s, you probably bent one. Check the outer and inner lips for bends.
Old May 13, 2003 | 11:22 PM
madmax97's Avatar
Ive check rims no bends...seem good to go. Also if they are bent what does this mean, is it safe to drive on. Would be causeing my problems ?
Old May 14, 2003 | 02:01 AM
drewm's Avatar
As long as they aren't letting out air, you're probably okay, just off ballance. Generally you won't be able to get them to ballance until you get them fixed.
To check for bends. (prepare to get hands dirty) Run you finger along the inner side of the lip, you can feel for bumps and irregularities better that way. Also do that to the backside of each rim. They are sometimes hard to feel for, but check carefully and will usually look like this:
http://www.villacorte.com/miata/ssr-...ems/flysi1.jpg
Old May 14, 2003 | 02:51 AM
Chinkzilla's Avatar
Also check your lower control arm, I broke one off the bushing once (in addition to bending a rim) and had similar symptoms to yours. Most likely, you just bent a rim. Head down to your local tire shop and see if they can put it on the wheel balancer thingy for you. That will usually tell you if it's out of round or not.
Lakersallday24
Jun 16, 2019 01:35 AM
MaximaDrvr
Aug 19, 2015 08:20 PM
Balkins
Aug 12, 2015 06:39 AM
kirkhilles
Aug 8, 2015 10:53 AM
BassAddictJ
Aug 4, 2015 11:38 AM
