Dyno numbers and an interesting story... :wall:
Old May 18, 2003 | 12:48 PM
Y2KevSE's Avatar
Rice Boy in Denial =)
Well, I have been running extremely lean for the past 3-4 months because the Walbro intank fuel pump wasn't working correctly. The pump would not put out the pressure and flow needed for anything over 4 psi. Best of all, I didn't find out about the bad pump until 2 weeks ago. So, get an in-cabin fuel pressure gauge!!!
Run #1: 317.3 whp, 314.4 tq
Run #2: 311.9 whp, 318.7 tq
Run #3: 308.5 whp, 317.4 tq
Here goes the dyno graph (best SC = red, best TC = blue):
We did 5 runs total, with each run putting out less and less hp after 5225 RPM. The largest difference in power (with all 6 cylinders semi-working) at 6500 is about 130 wheel hp and 120 ft-lb torque.
Here are pictures of the plugs after run #4:
http://boostedmaximas.com/y2kevse/im...no_turbo1a.jpg
http://boostedmaximas.com/y2kevse/im...no_turbo1b.jpg
http://boostedmaximas.com/y2kevse/im...no_turbo1c.jpg
I wasn't running the Aquamist water injection on the turbo dynos since the pump broke (found out 1.5 weeks ago). Both SC and TC dynos weren't fully tuned, so it may not be fair to compare the two without them being at their best hp and tq.
Did a compression check when I got home. Cylinders #1 through 5 are good, but #6 is a little weak.
Lesson of the day: Get an in-cabin fuel pressure gauge.
Old May 18, 2003 | 12:50 PM
gtr_rider's Avatar
192.168.1.1
Old May 18, 2003 | 01:07 PM
MardiGrasMax's Avatar
Not too shabby. IC must help the TC a bit, even more when its rolling im sure. You runing just water or a alch/water mix? J&S?
Old May 18, 2003 | 01:13 PM
SteVTEC's Avatar
Dyno plot says I have the most area under the Administrator curve
Nice numbers.
Cylinder #6.
Old May 18, 2003 | 01:23 PM
Bags's Avatar
VG Ridah's Biatch Hoe
looks good.. the TQ is really great
you think the bad cylinder is why you have a lull from 4700 - 6000?? or you think that is the fuel pump?
and do you make your peak HP at 4500 or 6500???
Your dyno is odd, kev... but maybe I am just not used to looking at a boosted 5th gen's
Maybe it is your engine/fuel???
I am just trying to understand it. The HP dips before the VIAS comes on, but the TQ does not. The HP also stays in that little valley for 1500 rpm.. granted, it is a 300 WHP valley so it ain't bad just different.
You running what size downpipe and exhaust?
thanks, I am just trying to get a good idea of what your seeing, I might need it in the future
Old May 18, 2003 | 03:03 PM
MAXIN's Avatar
What plugs are you running, and at what gap?
Old May 18, 2003 | 03:22 PM
Kev, were you auto for the SC dynos and 5spd for the TC dynos?
Old May 18, 2003 | 04:27 PM
Padsy's Avatar
Boost.....
Stay with it Kev......
Old May 18, 2003 | 04:36 PM
Methamphetamine's Avatar
You havent beat Jaime YET
Old May 18, 2003 | 04:41 PM
Padsy's Avatar
Boost.....
At least Jane's car is running.
I've got $20 that says she could whoop Kev's ****.
At the track boys.
Old May 18, 2003 | 04:44 PM
dwapenyi's Avatar
317 whp? Hmm, assuming a 17% loss thru the 5 speed tranny, that would be about 382 hp at the crank and 378 lb-ft of TQ. I guess that's adequate
Was your dyno session lean? It looks like it's rich , if anything. And our loss of power during each run, could that be atrributed simply to heat, of which a turbo setup must generate ALOT? And your plastic VIAS may not be able to dissipate that heat as fast as a metal manifold may have. When I dynoed NA, I kept getting weaker by 1 hp after each run.
Old May 18, 2003 | 05:34 PM
i dont think it'd be THAT much more to the crank (378)....more around 350 to the crank
Old May 18, 2003 | 06:05 PM
LatinMax's Avatar
What did the plug look like in cylinder #6?
That will tell you if you were lean or rich or what?
Old May 18, 2003 | 06:09 PM
thebigsadler's Avatar
looks good kev.. can't wait to get my go mods goin..
Old May 18, 2003 | 06:33 PM
HitManSE's Avatar
The Torque is whats catching my eye. Its got about 70 ft lbs more then a SC vq would give.
Old May 18, 2003 | 06:44 PM
190hpKiLLA's Avatar
Granny Driven
What should be the ideal compression?
Old May 18, 2003 | 09:06 PM
mtrai760's Avatar
'Trynna' is not a word
Dammit Kev, no fuel pressure gauge? Sorry to hear that. Whats your compression on cyl #6? I had a walborro pump go bad on me last year. Wouldn't hold pressure, started dropping down to 20psi, I had to bump it up with the AEM FPR or my car woulda died. I pulled the pump and was gonna send it back for warranty replacement when my car was broken into and it was stolen out of my trunk. Dumb kids stole a broke a$$ fuel pump, I hope they tried installing it in some ricer mobile Numbers HP wise look pretty good... I'm assuming thats your 5spd S/C dyno your comparing it with?
Old May 18, 2003 | 09:27 PM
hokiemax's Avatar
you were running turbo and NOS without a fuel pressure gauge?? oh man.. why did THAT walbro in your car had to break, and damaging your cylinder #6. Well you took a calculated risk when you were running without the FP gauge, and the .001% chance that the fuel pump would go bad became real. it sucks. sorry to hear that.
Old May 18, 2003 | 11:08 PM
Y2KevSE's Avatar
Wasn't running Aquamist, but I do 20/80 mixture (alch/water).
No J&S.
Originally posted by bags533
looks good.. the TQ is really great :-)
I think you're slightly confused with the graphs. Torque decreases as the RPM goes up. So at 4700, it makes ~317 torque. Then it dips until it hits ~250 at 6500. Peak hp is at about 6000... but I think it would have been stronger if the car was running correctly. Torque dips... hp rises.
3" downpipe into 2.5" cat and cat-back.
Was running one step colder coppers gapped at .035"
5 speed for both. Sometimes I wonder if the dyno is off or the car is retarded. I got better numbers before the shop switched dynos.
Don't worry, the nitrous will blow the motor up.
Not trying to beat anyone in peak numbers... but all I have to do is turn up the boost if I really wanted to get good numbers. :gotme
At the track boys.:kiss
Originally posted by dwapenyi
317 whp? Hmm, assuming a 17% loss thru the 5 speed tranny, that would be about 382 hp at the crank and 378 lb-ft of TQ. I guess that's adequate:wall :-)
Nope, it wasn't lean... but it was REALLY lean when it went 2 weeks ago (> 18:1 a/f). No, it wasn't the heat that was causing the power loss after each run. The dyno guy even thought it was weird after the 3rd run, and he specializes in turbo stuff.
5-15 hp... yeah that's understandable, but 70 hp after each run? That makes one wonder....
Check out the three links for pics. #4 and #6 had zero plug gap. Hehehehe
Good luck!
Old May 18, 2003 | 11:15 PM
Y2KevSE's Avatar
185.
Originally posted by mtrai760
Dammit Kev, no fuel pressure gauge? :slap :nono Sorry to hear that. Whats your compression on cyl #6? I had a walborro pump go bad on me last year. Wouldn't hold pressure, started dropping down to 20psi, I had to bump it up with the AEM FPR or my car woulda died. I pulled the pump and was gonna send it back for warranty replacement when my car was broken into and it was stolen out of my trunk. Dumb kids stole a broke a$$ fuel pump, I hope they tried installing it in some ricer mobile :laugh Numbers HP wise look pretty good... I'm assuming thats your 5spd S/C dyno your comparing it with?
Cylinder #6 is 120.
The inline fuel pressure gauge read 43 when I pulled it off the Cartech, but little did I know that pressure would not hold after 30 seconds of idling. The pressure would drop back down to 36 and stay there. Even pinching the fuel return line (back to gas tank) would not bump up the pressure.
Just turbo, since the NX kit isn't hooked up yet.
No idea why the Walbro failed, but it did. Lesson of the day... get an in-cabin fuel pressure gauge.
Old May 19, 2003 | 02:10 AM
hakk97se's Avatar
Old May 19, 2003 | 03:18 AM
Bags's Avatar
3inch downpipe into 2.5inch cat and cat-back.
AHH.. I confused the lines crossing.. bags
and the 2.5 inch exhaust has gotta be hurting you, but the 3 inch down pipe is great.. I am having problems fitting a 3 inch pipe in there.
thank you sir
Old May 19, 2003 | 05:47 AM
BigDogJonx's Avatar
Damn, this makes me think I have to do a compression test on my cylinders, I ran a bit lean couple weeks ago and burned up the EGT probe. Damn these turbos.
Dixit
Old May 19, 2003 | 05:53 AM
redmaxpa007's Avatar
i SeE what you did therE
your car is still slow....
bout time you got that thing to a dyno.
ps.. do you need a stillen boost gauge?
Old May 19, 2003 | 06:24 AM
Maxman2000's Avatar
Nice . Does that tubro kit put out around the same # of ponies as the stillen supercgarger kit????
Old May 19, 2003 | 06:36 AM
mingo's Avatar
i remember how u were saying something about ur fuel pressure gauge not reading anything when we were looking at my friend's TT
Old May 19, 2003 | 06:40 AM
UMD_MaxSE's Avatar
Got Bent?
Old May 19, 2003 | 08:19 AM
Y2KevSE's Avatar
Originally posted by hakk97se
See you later today.
AHH.. I confused the lines crossing.. bags:smash
thank you sir :-D
I'm sure the 2.5 cat-back is hurting performance, but I can't do anything about it yet.
If you rework the piping, I'm sure you can get it in there. Your downpipe is too close to "stuff" so it might not be safe just putting a 3" on there as is.
Dixit
Definitely.
Originally posted by redmaxpa007
your car is still slow....:laugh
ps.. do you need a stillen boost gauge?:naughty
I know it's slow. :-o
I had 3 boost gauges: 1) boost controller, 2) turbo timer, and 3) A'PEXi... Delio is getting the A'PEXi gauge so I'll have two.
Originally posted by Maxman2000
Nice :eek . Does that tubro kit put out around the same # of ponies as the stillen supercgarger kit????
It "should" put out around he same peak numbers but the low and mid-range hp/tq will be better.
Yup... the inline fuel pressure gauge wasn't positive when the car was shut off.
Originally posted by UMD_MaxSE
:nervous
Make or break, I'm still gunning for 375 whp with turbo and nitrous on this motor.
Old May 19, 2003 | 08:48 AM
LatinMax's Avatar
Quoted Message:
185.
Correction it should be 220...trust me I know.
Old May 19, 2003 | 08:49 AM
Bags's Avatar
Oh heL YEAH!!!
I am shooting for 350 WHP when it is said and done... on any motor
and can I get a Yeah come'on
Old May 19, 2003 | 08:58 AM
xHypex's Avatar
Nope, it wasn't lean... but it was REALLY lean when it went 2 weeks ago (> 18:1 a/f). [/B]
You have all these gauges and no FP gauge Also were you running a wideband to know about the A/F?
I know running lean is bad, but isn't 18:1 REALLY high
-hype
Old May 19, 2003 | 09:40 AM
Y2KevSE's Avatar
Quoted Message:
185.
185 standard and 142 minimum per ESM on page EM-12.
Oh heL YEAH!!!
and can I get a Yeah come'on :eek
Originally posted by xHypex
You have all these gauges and no FP gauge :goofy Also were you running a wideband to know about the A/F?
I know running lean is bad, but isn't 18:1 REALLY high :gotme
-hype
Nope, no fuel pressure gauge. I'd figure the inline fuel pressure gauge would have been enough since I can look at the FP while adjusting the FMU... guess not!
I wasn't running a wideband myself, but I found out > 18:1 about 2 weeks ago on the dyno.
Old May 19, 2003 | 10:43 AM
UMD_MaxSE's Avatar
Got Bent?
Don't you have a tomei A/F gauge? I thought that came with a wideband O2 sensor
Old May 19, 2003 | 11:08 AM
Y2KevSE's Avatar
Not hooked up after turbo install.
Old May 19, 2003 | 11:13 AM
UMD_MaxSE's Avatar
Got Bent?
you know I just thought of that after I posted...
Old May 19, 2003 | 11:18 AM
Y2KevSE's Avatar
EGT readings were normal though. I even thought I was running rich in the beginning.
Old May 19, 2003 | 11:22 AM
UMD_MaxSE's Avatar
Got Bent?
time for a new fuel pump...
hopefully not a new engine
Old May 19, 2003 | 12:44 PM
Y2KevSE's Avatar
Using Jane's T-rex pump and working on building an engine.....
... already started to research.
Old May 19, 2003 | 01:29 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
SOOOoooo...you dynoed 2-weeks ago and didn't tell us, huh?
Your fuel needs leaning at 3500-4500. Your hp/tq curve looks like it's begging for it.
Now that's some TORQUE!!!!! What's next?
Old May 19, 2003 | 02:21 PM
Craig Mack's Avatar
All YOUR grammer belong to me
Torque Shmorque.....it's worthless.
