Got the gauge, how to perform cylinder compression
Old May 21, 2003 | 12:26 PM
190hpKiLLA's Avatar
Granny Driven
My friends do it like this on their 4 bangers:
remove all plugs/wires, disconnect the ECU fuse so the fuel doesnt not shoot out. And then crank the car 5 times at WOT and notice the compression.
Is this the right way or there is a better way.
Compression should be 185?
Thank you.
Old May 21, 2003 | 12:33 PM
Jime's Avatar
The only thing I do other than what you are doing is full throttle and do it till it stops rising. Try and position the gauge so you can see it from the cockpit.
Old May 21, 2003 | 12:35 PM
190hpKiLLA's Avatar
Granny Driven
thanks i totaly forgot.
Jeff92se's Avatar
I'm needing a caw
http://www.cybrrpartspro.com/Chilton...61CH03_26.HTML
Old May 21, 2003 | 12:44 PM
190hpKiLLA's Avatar
Granny Driven
U are the man!
Old May 21, 2003 | 01:17 PM
PCGuRu2K's Avatar
Dude do my compression test this weekend for me
Old May 21, 2003 | 03:14 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Jeff,
You don't need to EITHER disconnect the injectors OR pull the fuel pump fuse and let it die, first?
Old May 21, 2003 | 03:16 PM
Jeff92se's Avatar
I'm needing a caw
I disconnected the ignition signal that tells the plug coils to fire. I don't think I disconnected the fuel injector harness.
Originally posted by IceY2K1
Jeff,
Old May 21, 2003 | 03:19 PM
IceY2K1's Avatar
Then the fuel will puddle or shoot out plug hole/exhaust port right?
Also, do you HAVE to remove all the plugs or can you just remove/replace one at a time? Does it make a difference?
Old May 21, 2003 | 03:21 PM
Jeff92se's Avatar
I'm needing a caw
Fuel doesn't shoot anywhere. You could unplug the main injector harness if it worries you. Take all the plugs out. Reason? Because it will make cranking the car over MUCH easier on the battery.
Old May 21, 2003 | 03:23 PM
IceY2K1's Avatar
Jeff92se's Avatar
I'm needing a caw
Wanger!
Old May 21, 2003 | 03:26 PM
IceY2K1's Avatar
Mahmuth
Aug 16, 2024 08:23 PM
jmlee44
Oct 2, 2022 02:13 PM
aw11power
Oct 10, 2021 04:57 AM
Miket2006
Mar 1, 2021 03:55 AM
