Camber Kit & Sprint spring
Old Jan 25, 2001 | 03:44 PM
ejj's Avatar
ejj
Hey guys -
Can someone explain to me exactly what a camber kit would do if installed with these springs? I remember reading that it was necessary, but now I've heard of people installing Sprints without it.
What is involved in installing the camber kit?
Thanks.
Old Jan 25, 2001 | 04:08 PM
seven's Avatar
the camber bolts are just bolts...
they're thinner than the stock bolts so that they can be adjusted +/- 1.00 for camber.
Old Jan 25, 2001 | 04:12 PM
sleeper's Avatar
seven
is that saying in your sig, a bruce lee quote?
Old Jan 25, 2001 | 05:31 PM
Chebosto's Avatar
RIceD OuT moDErAtor
you'll need to adjust the camber when installing lowering springs lower than 1.75 inches.
so for the SPrints, you can get Ingall's Camber bolts thru TireRack.com for like $35.
or you can go all out with the pro-kit Camber +/- 3 degree with the stillen camber set. but that's not necessary
the bolts just push in or out, depending on the alignment.
hope that helps,
--Cheston
Old Jan 25, 2001 | 05:41 PM
ejj's Avatar
ejj
How do you know how much to adjust the camber...or do you leave that to who is doing the alignment?
Apr 16, 2020 05:15 AM
MaxLvr21
Oct 17, 2015 12:11 PM
JakeOfAllTrades
Sep 30, 2015 03:16 PM
Pied
Sep 26, 2015 03:29 PM
