Where are existing holes in firewall....
Old May 29, 2003 | 02:58 PM
Gotrice4's Avatar
I have a '95 max and I have some Raybrig fogs that started with a wireless remote but now I'm planning to actually hardwire them. I was wondering if someone had a pic to show where the existing hole in the firewall is and how to wire say foglights, to get the wires from the engine into the cabin? Sorry, I would've searched, but it seems to be disabled again. Thanks in advance.
Old May 29, 2003 | 03:52 PM
KLoWnPR109's Avatar
get a flashlight, get under there and start looking. There will be a grommet with wires going through it, that's what I used for my power wire.
Old May 29, 2003 | 11:40 PM
IceY2K1's Avatar
Fastest Fantasy Maxima Evar
Turn the wheels all the way to the left, unscrew/unsnap the rear half of the fender liner on the DRIVERS' side and fold it back.
You will see a LARGE rubber grommet with wires running through into the cabin. Just use a screw driver or stiff wire to poke/pull through into the cab.
Old May 30, 2003 | 04:30 AM
PCGuRu2K's Avatar
You can always drill another hole through the cabin firewall. I have a bunch
Old May 30, 2003 | 04:46 AM
redmaxpa007's Avatar
i SeE what you did therE
Old May 30, 2003 | 05:31 AM
Confused's Avatar
Permanent Maxima.org Resident
if you look behind the intake manifold (just below the top) left of the center line you will see a fairly flat rubber circle about 1.25" in diameter. Pull it out and then crawl under your dash, its not a perfect alignment but surely good enough.
Old May 30, 2003 | 09:57 AM
pocketrocket's Avatar
Don't go crazy with the harness grommet and use a sharp object (screwdriver, etc) to jab the area between the wires. Soft grommet area is good.
uttadms31
Sep 30, 2015 05:24 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
Dasmith
Sep 23, 2015 08:28 PM
2kmaximel
Sep 16, 2015 03:19 PM
2kmaximel
Sep 10, 2015 08:13 AM
