factory remote blues
Old May 30, 2003 | 07:14 AM
mazdamike's Avatar
my ques is simple .
does anyone here know how to reprogram a factory remote for a 96 GLE?
i have a remote from another car that ofcourse doesnt work for my car but how can i program it to work on my car?
any help would be appreacated
mgacura@aol.com
Old May 30, 2003 | 07:31 AM
bananamax's Avatar
Must be "scanned" at a dealer. Though you may be able to find someone else wit hthe tool.
Old May 30, 2003 | 07:36 AM
gtr_rider's Avatar
192.168.1.1
ummmm no.
Replacing Remote Controller or Multi-Remote Control Unit (LCU05)
Enter the identity (ID) code manually when:
remote controller or multi-remote control unit LCU05 is replaced.
an additional remote controller is activated.
ID Code Entry Procedure
To enter the ID code, follow this procedure.
Entering "Setting mode":
(1) Close and lock all doors.
(2) Insert and remove the key from the ignition more than six times within 10 seconds. (The hazard warning lamp will then flash twice.) At this time, the original ID codes are eliminated.
ID code entry:
(3) Turn ignition key to "ACC" position.
(4) Push lock button on the new remote controller once (for example, if door is locked using the remote controller during this ID code entry enable state, a new ID code can be entered). At this time, the new ID code is entered. (The hazard warning lamp will then flash twice.)
Additional ID code entry
(5) If you need to activate additional remote controllers, unlock the driver's door, then lock again with door lock ****.
(6) Push lock button on the additional new remote controller once.
(7) This ID code entry enable state and setting mode remain until the driver's door is opened.
NOTE
If you need to activate more than two additional new remote controllers, repeat the procedure "Additional ID code entry" for each new remote controller.
If the same ID code that exists in the memory is input, the hazard warning lamps will flash twice but the entry will be ignored.
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignored.
Any ID codes entered after termination of the "setting mode" will not be accepted. Additionally remote control signals will be inhibited when an ID code has not been entered during the "setting" mode.
Old May 30, 2003 | 08:53 AM
redmaxpa007's Avatar
i SeE what you did therE
once again.. luke shows us why he is the man!!!
Old May 30, 2003 | 09:03 AM
gtr_rider's Avatar
192.168.1.1
Old May 30, 2003 | 09:04 AM
Originally posted by gtr_rider
isn't it great to be online during the day?
Old May 30, 2003 | 09:53 AM
pocketrocket's Avatar
Is someone bumming at home?
tarun900
19
Dec 20, 2021 06:57 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
BobTX10
Oct 7, 2015 08:43 AM
worldwiderecognized
Sep 30, 2015 01:16 PM
